StarTech.com HDMI capture device - USB video capture
Quicklinx: DZ72WS00 Mfr#: UVCHDCAP
£178.61 ex VAT
£214.33 inc VAT
Record video and audio to your Windows or Mac computer using this USB-C video capture device. This HDMI to USB-C video capture device lets you record HDMI video to your USB-C, USB-A or Thunderbolt 3 computer, and features a durable aluminum enclosure so it can safely travel with your laptop.
For hassle-free recording, you can install the HDMI capture device by simply connecting it to your computer. The capture device features USB Video Class (UVC), a video capture standard that's natively supported by Mac, Windows and Linux . Unlike other capture devices that require proprietary driver installation, UVC based capture devices install automatically for a truly plug-and-play solution. Also, with this capture device you're not limited to the included software. You can use any third-party software that uses UVC compatible frameworks such as Quicktime or DirectShow.
Record 1080p video at 60fps (frames per second), to save your content so it can be shared, stored, or edited. Capture meetings, presentations, conference calls and from security equipment directly to your computer.
Stream your video over the internet using Twitch or other third-party video streaming platforms. With the included software or your own third-party UVC compatible software like Open Broadcaster Software (OBS), you can live broadcast video over the internet using Twitch or other third-party video streaming platforms.
StarTech.com HDMI to USB C Video Capture Device - USB Video Class - 1080p - 60fps - Thunderbolt 3 Compatible - HDMI Recorder (UVCHDCAP) - video capture adapter - USB 3.0
Video capture adapter
Interface Type
USB 3.0
6 cm x 9.2 cm x 2.3 cm
88 g
Black, silver
Video Input
HDMI input
Video Modes
1080/60p
Digital Video Format
MPEG-4, H.264
Digital Video Capture Speed
60 frames per second
Digital Video Capture Resolution
1080p
Audio Input Support
Standard
USB Video class
Apple MacOS, Linux, Android, Microsoft Windows 7 / 8 / 10
Interface Type
USB 3.0
6 cm
9.2 cm
2.3 cm
88 g
Black, silver
Video
Interface Type
HDMI input
Video Modes
1080/60p
MPEG-4, H.264
1080p
Still Image Capture Resolution
1080p
Audio Input Support
Standard
USB Video class
1 x audio / video - HDMI input - 19 pin HDMI Type A , 1 x audio - input - mini-phone stereo 3.5 mm , 1 x USB - SuperSpeed USB 3.0 - 9 pin USB Type B
1 x SuperSpeed USB 3.0 - 9 pin USB Type B
1 x USB-C to USB-B cable - external , 1 x USB-A to USB-B cable - external , 1 x HDMI cable - external
Device Features
USB powered
FCC, RoHS, WEEE
TAA Compliant
Shipping Weight
90 g
20 - 80% (non-condensing)
DZ72 StarTech.com S-Video / Composite to USB Video Capture Cable w/ TWAIN and Mac Support In Stock £29.28
DZ72 StarTech.com PCIe HDMI & VGA Capture Card In Stock £121.38
Price Range Ex VAT: 150 - 300
