This USB to HDMI video capture device enables HDMI A/V recording, at up to 4K 30Hz, to a USB-C or USB-A enabled computer.
Record 4K Video
The USB 3.2 Gen 1 (5Gbps) Capture Device enables recording of HDMI audio and video. Capture at up to 2160p 30fps, 1440p 60fps or 1080p 120fps with 16-bit PCM audio using third party software that supports DirectShow or QuickTime. Ideal for capturing the HDMI output of DSLR cameras, action cameras, webcams, and more. -
USB Video Class
The capture device features USB Video Class (UVC), a video capture standard that's natively supported by Mac, Windows, and Ubuntu. USB bus-power and UVC facilitate plug and play installation. The included USB-A and USB-C cables let you connect to almost any host device running a supported operating system. -
Capture or Stream
Record conference calls, presentations, security feeds, training videos, and more using third party software. Live stream content for community events, remote troubleshooting, or educational purposes on platforms supporting RTSP or RTMP communication protocols. The Capture Device works with Teams, Google Hangouts, Zoom, Adobe Connect, GoToMeeting, and more. 4K30-HDMI-CAPTURE is backed for 2-years by StarTech.com, including free 24/5 multi-lingual technical assistance. Note: This device is HDCP compliant, and will not capture copy protected video, such as Blu-rays or the video output of Mac computers. However, this device will capture video to Mac computers and will capture non-encrypted video.
- StarTech.com USB 3.0 HDMI Video Capture Device, 4K Video Capture Adapter/External USB Capture Card, UVC, Live Stream, HDMI Audio/Video Screen Recorder, Works w/ USB-A, USB-C, Thunderbolt 3 - Windows/Mac/Ubuntu (4K30-HDMI-CAPTURE) - video capture adapter - USB 3.0
- Video capture adapter
- Interface Type
- USB 3.0
- 4.4 cm x 7.3 cm x 1.2 cm
- 41 g
- Grey
- Video Input
- HDMI input
- Video Modes
- 2160/30p, 3840/30p, 1440/60p, 1080/120p
- Digital Video Format
- MPEG-4, MJPEG, H.264, YUY2, H.265
- Digital Video Capture Speed
- 30 frames per second
- Digital Video Capture Resolution
- 3840 x 2160
- Audio Input Support
- Standard
- Live Streaming, USB Video class
- OS Required
- Apple macOS 10.14, Apple macOS 10.15, Ubuntu 20.04, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- 2-year warranty
- Interface Type
- USB 3.0
- 4.4 cm
- 7.3 cm
- 1.2 cm
- 41 g
- Grey
Video
- Interface Type
- HDMI input
- Video Modes
- 3840 x 2160
- Still Image Capture Resolution
- 3840 x 2160
- Standard
- 1 x audio / video - HDMI input - 19 pin HDMI Type A , 1 x USB - SuperSpeed USB 3.0 - 9 pin USB Type B
- Cables Included
- 1 x USB-C to USB-B cable - external - 40 cm , 1 x USB-A to USB-B cable - external - 40 cm
- Device Features
- USB powered
- HDCP 1.4
- OS Required
- Shipping Width
- 12.5 cm
- Shipping Depth
- 15.9 cm
- Shipping Height
- 2.6 cm
- Shipping Weight
- 181 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 20 - 90%
StarTech.com 3ft Premium Certified HDMI 2.0 | In Stock | £13.26 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £16.15 |
StarTech.com 50cm Premium Certified HDMI | In Stock | £10.42 |
