Convert and extend a Gigabit Ethernet connection up to 550 m / 1804 ft over Multi Mode SC fiber. The ET91000SC2 1000 Mbps Gigabit Multimode Fiber Media Converter (SC, 550m) lets you extend a Gigabit Ethernet network over multimode fiber, at distances up to 550m (1804 ft).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, the GbE to MM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet to fiber solution, this Ethernet to SC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, the fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
 - StarTech.com Multimode (MM) SC Fiber Media Converter for 1Gbe Network - 550m Range - Gigabit Ethernet -Remote Monitoring - 850nm (ET91000SC2) - fibre media converter - 1GbE
 - Fibre media converter - RJ-45 / SC multi-mode
- Form Factor
 - External
- Localisation
 - North America, United Kingdom, Europe
- Cabling Type
 - 1000Base-LX, 1000Base-SX, 1000Base-T
- Data Transfer Rate
 - 1 Gbps
- Optical Wave Length
 - 850 nm
- Data Link Protocol
 - 1GbE
- Max Transfer Distance
 - 550 m
- Power
 - AC 120/230 V
 - 9.5 cm x 16 cm x 2 cm
 - 0.62 kg
 - 2-year warranty
- Designed For
 - P/N: ETCHS2U, SVA12M2NEUA, SVA12M5NA
- Form Factor
 - External
 - Black
- Localisation
- Connectivity Technology
 - Wired
- Cabling Type
 - 1GbE
 - 1 Gbps
 - 850 nm
 - 550 m
 - Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, rugged
 - 1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX/1000Base-SX - SC multi-mode female x 2
- MTBF
 - 65,000 hours
 - Plug and Play, FCC, RoHS
- Power Device
 - External power adapter
- Voltage Required
 - AC 120/230 V
 - 9.5 cm
 - 16 cm
 - 2 cm
 - 0.62 kg
 - Limited warranty - 2 years
 - 0 °C
 - 60 °C
 - 10 - 90%
- Designed For
                        StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps | In Stock | £145.25 |
                        StarTech.com Fiber Media Converter - Open | In Stock | £42.26 |
                        StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.68 |
                        StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.02 |
                        StarTech.com USB 3 Fiber Converter Open SFP | In Stock | £175.88 |
                        StarTech.com USB C to Fiber Optic Converter | In Stock | £180.63 |
