StarTech.com Full Motion TV Mount - Steel
Quicklinx: CWBWWS00 Mfr#: FPWARTB1M
Type: Mounting kit
37 In Stock
£62.89 ex VAT
£75.46 inc VAT
Free up space by mounting your flat-panel TV on a wall, with full-motion adjustment capability. Maximize space while creating an impressive display. This heavy-duty steel TV wall mount securely supports flat-screen TVs from 22" to 55". The arm extends easily to provide smooth, full-motion positioning for ideal viewing.
Mount your flat-screen TV in a location that's convenient for visitors, clients and employees. This TV wall mount is ideal for the lobby, boardroom or other venues, providing an impressive and secure way to display a flat-panel TV or mount digital signage. It also frees up valuable space. The TV wall mount supports most 22" to 55" (558.8 to 1397 mm) LED or LCD flat panel TVs weighing up to 77 lb. (35 kg).
The TV wall mount provides full-motion adjustment capability. The arm extends up to 19.8" (503 mm) from the wall to provide a wide range of movement and accommodate different screen positions and angles. The arm can also fold to tuck-in closely to the wall, providing a minimized profile, which enables you to position your display just 1.9" (49 mm) from the wall.
The TV wall mount swivels +90° / -90° to provide maximum viewing flexibility. The mount also tilts +2° / -12°, letting you angle your TV display toward your audience. With the tilt feature, you can mount your TV lower or higher than eye level and still view it comfortably.
The robust steel design safely and securely supports your flat-screen TV, to protect your investment. The TV wall mount also includes plastic brackets for cable management to keep cables neatly out of sight.
  • Mount Your Monitor to Save Valuable Space
    Mount your flat-screen TV in a location that's convenient for visitors, clients and employees. This TV wall mount is ideal for the lobby, boardroom or other venues, providing an impressive and secure way to display a flat-panel TV or mount digital signage. It also frees up valuable space. The TV wall mount supports most 32" to 55" (558.8 to 1397 mm) LED or LCD flat panel TVs weighing up to 77 lb. (35 kg).
  • Full-Motion Adjustment
    The TV wall mount provides full-motion adjustment capability. The arm extends up to 19.8" (503 mm) from the wall to provide a wide range of movement and accommodate different screen positions and angles. The arm can also fold to tuck-in closely to the wall, providing a minimized profile, which enables you to position your display just 1.9" (49 mm) from the wall. The TV wall mount swivels +90 / -90 degrees to provide maximum viewing flexibility. The mount also tilts +2 / -12 degrees, letting you angle your TV display toward your audience. With the tilt feature, you can mount your TV lower or higher than eye level and still view it comfortably.
  • Heavy-Duty Construction
    The robust steel design safely and securely supports your flat-screen TV, to protect your investment. The TV wall mount also includes plastic brackets for cable management to keep cables neatly out of sight. The FPWARTB1M is backed by a StarTech.com 5-year warranty and free lifetime technical support.
StarTech.com Full Motion TV Wall Mount, 32-55 inch (77lb/35kg) VESA Displays, Low Profile Universal Flat Screen TV Wall Mount, Heavy Duty Adjustable Tilt/Swivel Articulating Arm Bracket - Cable Management mounting kit - for TV - black
Mounting kit - wall-mountable
Mounting Components
Articulating arm, wall mount, wrench
Tilt
-12° to 2°
Pan
-90° to 90°
Adjustments
Horizontal
Recommended Use
TV
Recommended Display Size
32"-55"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 300 x 200 mm, 200 x 100 mm, 300 x 300 mm, 100 x 150 mm
Max Load Weight
35 kg
Material
Plastic, steel
Package Content
4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 8 x washers, 4 x M8x50 screws, 4 x bracket screws, 4 x nuts, 16 x spacers, 4 x VESA extension brackets, 4 x concrete screws, 4 x bracket washers, 4 x screws
5-year warranty
P/N: HDMIPLATE
Material
Plastic, steel
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
TV
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
32"-55"
Tilt
-12° to 2°
Pan
-90° to 90°
Adjustments
Horizontal
Max Load Weight
35 kg
Limited warranty - 5 years
P/N: HDMIPLATE
CWBW StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter In Stock £36.61
CWBW StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable In Stock £5.32
CWBW StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.83
CWBW StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £78.22
CWBW StarTech.com Full Motion TV Wall Mount In Stock £251.75
CWBW StarTech.com VESA TV Wall Mount Full Motion In Stock £88.62
Type: Mounting kit
