StarTech.com VESA TV Wall Mount Full Motion
Quicklinx: H3C3WS00 Mfr#: FHA-TV-WALL-MOUNT
Type: Mounting kit
10 In Stock
£104.42 ex VAT
£125.30 inc VAT
The steel and aluminum construction of this VESA TV Wall Mount supports TVs from 23" to 55" and up to 66lb (30kg). The arm assembly provides smooth one-touch height adjustment thanks to its spring-loaded mechanism that acts as a counterbalance. The VESA plate supports mounting patterns of 75x75 to 400x400.
  • Versatile TV Mounting
    Securely mount a flat or curved-screen TV or digital signage in a convenient location for viewing by visitors, clients, and employees. This TV wall mount is ideal for lobbies, boardrooms, and manufacturing facilities. The lateral range of 3.54 ft (1.08m) is ideal for corner mounting. The jointed arm folds on itself and creates a slim profile from the wall of just 2.2in (5.8cm) for limited space installations. The minimum TV weight is 17.6lb (8kg). M5/M6/M8 Screws of various lengths and an assortment of washers and spacers enhance TV mounting compatibility. Mount into wood-stud or concrete walls, using the included hardware. Supported VESA mounting patterns: 75x75,100x100, 200x100, 200x200, 300x300, 400x200, and 400x400.
  • Full-Motion Adjustment
    The VESA plate swivels +90 / -90 degrees, tilts +8 / -15 degrees, and rotates +3 / -3 degrees. Customize the viewing experience and comfort with these full-motion capabilities. The one-touch spring-assisted mechanism facilitates effortless height adjustments, with a range of up to 12.6in (32cm). The arm assembly extends up to 23.4 in (59.5 cm) from the wall to accommodate different viewing positions.
  • Durable Construction
    The robust steel and aluminum design safely and securely supports the TV. The arm assembly features built-in cable management and a wall mount cover for a an organized and visually appealing installation. The height adjustable TV wall mount is backed for two years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com VESA TV Wall Mount, TV Mounting Bracket For 23"-55" Displays, Adjustable Full Motion TV Wall Mount Supports 66lb (30kg), Extendable/Tilting/Swivel Monitor Wall Mount - Low Profile/Slim Display Mount (FHA-TV-WALL-MOUNT) mounting kit - for flat panel - TV Mounting Bracket - black, silver
Mounting kit - wall-mountable
45 cm x 59.5 cm x 45 cm
Tilt
-15° to 8°
Rotation
-3° to 3°
Swivel
-90° to 90°
Adjustments
Tilt, swivel, rotation
6 kg
Recommended Use
Flat panel
Recommended Display Size
23"-55"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 200 x 100 mm, 300 x 300 mm
Max Load Weight
30 kg
Material
Aluminium, steel
Black, silver
Package Content
4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, hex key (4mm), spirit level, 8 x spacers (long), 8 x spacers (short), 4 x M8x50 screws, wrench, hex key (6mm), 2 decorative covers, 8 x VESA extension plate screws, 4 display washers (large), 4 display washers (small), 2 x VESA extension plates (left), 2 x VESA extension plates (right), 5 wall mounting screws, 5 wall mounting washers
45 cm
59.5 cm
45 cm
6 kg
Material
Aluminium, steel
Black, silver
Package Content
AV Furniture
Mounting kit
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
23"-55"
Tilt
-15° to 8°
Rotation
-3° to 3°
Swivel
-90° to 90°
Adjustments
Max Load Weight
30 kg
Dimensions & Weight Details
58.5 cm x 44 cm x 9.5 cm / 6.1 kg
H3C3 StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £78.49
Type: Mounting kit
