Free up space by mounting your flat-panel TV on a wall, with full-motion adjustment capability. Maximize space while creating an impressive display. This heavy-duty steel TV wall mount securely supports flat-screen TVs from 22" to 55". The arm extends easily to provide smooth, full-motion positioning for ideal viewing.
Mount your flat-screen TV in a location that's convenient for visitors, clients and employees. This TV wall mount is ideal for the lobby, boardroom or other venues, providing an impressive and secure way to display a flat-panel TV or mount digital signage. It also frees up valuable space. The TV wall mount supports most 22" to 55" (558.8 to 1397 mm) LED or LCD flat panel TVs weighing up to 77 lb. (35 kg).
The TV wall mount provides full-motion adjustment capability. The arm extends up to 19.8" (503 mm) from the wall to provide a wide range of movement and accommodate different screen positions and angles. The arm can also fold to tuck-in closely to the wall, providing a minimized profile, which enables you to position your display just 1.9" (49 mm) from the wall.
The TV wall mount swivels +90° / -90° to provide maximum viewing flexibility. The mount also tilts +2° / -12°, letting you angle your TV display toward your audience. With the tilt feature, you can mount your TV lower or higher than eye level and still view it comfortably.
The robust steel design safely and securely supports your flat-screen TV, to protect your investment. The TV wall mount also includes plastic brackets for cable management to keep cables neatly out of sight.
Mount Your Monitor to Save Valuable Space
Mount your flat-screen TV in a location that's convenient for visitors, clients and employees. This TV wall mount is ideal for the lobby, boardroom or other venues, providing an impressive and secure way to display a flat-panel TV or mount digital signage. It also frees up valuable space. The TV wall mount supports most 32" to 55" (558.8 to 1397 mm) LED or LCD flat panel TVs weighing up to 77 lb. (35 kg). -
Full-Motion Adjustment
The TV wall mount provides full-motion adjustment capability. The arm extends up to 19.8" (503 mm) from the wall to provide a wide range of movement and accommodate different screen positions and angles. The arm can also fold to tuck-in closely to the wall, providing a minimized profile, which enables you to position your display just 1.9" (49 mm) from the wall. The TV wall mount swivels +90 / -90 degrees to provide maximum viewing flexibility. The mount also tilts +2 / -12 degrees, letting you angle your TV display toward your audience. With the tilt feature, you can mount your TV lower or higher than eye level and still view it comfortably. -
Heavy-Duty Construction
The robust steel design safely and securely supports your flat-screen TV, to protect your investment. The TV wall mount also includes plastic brackets for cable management to keep cables neatly out of sight. The FPWARTB1M is backed by a StarTech.com 5-year warranty and free lifetime technical support.
- Startech Full Motion TV Wall Mount, 32-55 inch (77lb/35kg) VESA Displays, Low Profile Universal Flat Screen TV Wall Mount, Heavy Duty Adjustable Tilt/Swivel Articulating Arm Bracket - Cable Management mounting kit - for TV - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Articulating arm, wall mount, wrench
- 40 cm x 61.4 cm x 40 cm
- Tilt
- -12° to 2°
- Pan
- -90° to 90°
- Adjustments
- Horizontal
- 2.8 kg
- Recommended Use
- TV
- Recommended Display Size
- 32"-55"
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 300 x 200 mm, 200 x 100 mm, 300 x 300 mm, 100 x 150 mm
- Max Load Weight
- 35 kg
- Material
- Plastic, steel
- Black
- Package Content
- 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 8 x washers, 4 x M8x50 screws, 4 x bracket screws, 4 x nuts, 16 x spacers, 4 x VESA extension brackets, 4 x concrete screws, 4 x bracket washers, 4 x screws
- 5-year warranty
- Designed For
- P/N: HDMIPLATE
- 40 cm
- 61.4 cm
- 40 cm
- 2.8 kg
- Material
- Plastic, steel
- Black
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- TV
- Placing / Mounting
- Wall-mountable
- Cable Management
- Integrated cable management
- 32"-55"
- Tilt
- -12° to 2°
- Pan
- -90° to 90°
- Adjustments
- Horizontal
- Max Load Weight
- 35 kg
- Limited warranty - 5 years
- Designed For
- P/N: HDMIPLATE
StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter | In Stock | £32.94 |
StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable | In Stock | £5.45 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £16.00 |
StarTech.com 10m CL2 Active HDMI Cable - 4K | In Stock | £81.45 |
StarTech.com Full Motion TV Wall Mount | In Stock | £253.81 |
StarTech.com VESA TV Wall Mount Full Motion | In Stock | £87.44 |
