Mount a flat-panel television to your ceiling with adjustable pole length, tilt and pan for easy viewing. Save space and mount your flat-screen television in the ideal viewing location, by suspending it from the ceiling. This robust steel ceiling mount supports VESA mount compatible TVs up to 70" in size. It's easy to adjust, so you can change the distance from the ceiling, and tilt or pan to create the optimal viewing angle.
The TV ceiling mount lets you mount your flat-panel LCD, LED or plasma TV in a prominent and comfortable viewing area while saving wall, desk and floor space. It's ideal for use in corporate boardrooms, hotel lobbies, restaurants, bars and meeting spaces. The heavy-duty TV ceiling mount works with 32 to 70" displays, and supports a weight capacity of up to 50 kg (110 lb.), making it compatible with a wide selection of TVs. To keep the cables out of view, you simply run the cables through the inside of the pole, exiting near the top.
With an adjustable pole length, the telescopic-style pole makes it easy to mount your display at the desired distance from the ceiling and works well with a range of ceiling heights. The robust steel pole can extend up to 1560 mm (61 in.) at maximum length, working well with most drop ceilings which are often found in commercial environments. The ceiling mount offers an extension range of 42 in. (1060 mm) to 61 in. (1560 mm) from the ceiling and features a height adjustment of 500 mm (19.7").
The LCD ceiling mount is designed to accommodate a wide variety of ceiling types. The ceiling mount swivels, so you can adjust the mount to work with virtually any type of ceiling for level viewing, including sloped ceilings (up to 60°), and pitched or horizontal (flat) ceilings. The extension pole also swivels + 180° / - 180° for optimum viewing.
You can adjust your flat-screen TV to create a comfortable viewing angle, by tilting it (up to -25°) down towards your audience for optimum visibility. The ceiling mount also features a 360° pan, which makes it easy to set up for viewing from any direction you choose.
The hook-and-mount design of the TV ceiling mount makes setup fast and easy. You simply attach the vertical brackets, with built-in hooks, to the back of your TV. Once the brackets are attached, you then hang your TV securely onto the ceiling mount. Cable management helps to keep cables out of view.
Adjustable Height
With a telescopic pole, the TV mount lets you suspend a display at your desired distance from the ceiling. This works well with a range of ceiling heights. The steel pole can extend from 42" to 61" (1060 to 1560 mm) , with a total lift (height extension) of 19.7" (500 mm). -
Swivels to Suit Your Ceiling
The flat-screen ceiling mount accommodates a wide variety of ceiling types. You can swivel the TV to work with virtually any type of ceiling for level viewing, including sloped ceilings (up to 60 degrees), and pitched or horizontal (flat) ceilings. -
Viewable from Any Direction
You can adjust your TV to create a comfortable viewing angle, by tilting it up to -25 degrees down towards your audience for optimum visibility. Plus, the full-motion mount lets you swivel your display around the pole + 180 / - 180 degrees, without using tools. -
Hook-and-Mount Design
Simply attach the included vertical brackets, with built-in hooks, to the back of your TV. Once attached, hang your TV securely onto the ceiling mount. The +/-3 degree post-installation leveling adjustments ensure ideal positioning after hanging. FLATPNLCEIL is backed by a StarTech.com 5-year warranty and free lifetime technical support.
- StarTech.com Ceiling TV Mount - 3.5' to 5' Pole - Full Motion - Supports Displays 32” to 75" - For VESA Mount Compatible TVs (FLATPNLCEIL) bracket - for flat panel - black
- Product Type
- Bracket - ceiling mountable
- 14 cm x 68 cm x 1.8 m
- Adjustable Height
- 0-50 cm
- Tilt
- 0° to 25°
- Rotation
- 360°
- Adjustments
- Height, pan, tilt, swivel
- 6 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-75"
- VESA Mounting Interface
- 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
- Max Load Weight
- 50 kg
- Material
- Steel
- Black
- 5-year warranty
- Designed For
- P/N: HDMIPLATE
- 14 cm
- 68 cm
- 1.8 m
- Adjustable Height
- 0-50 cm
- 6 kg
- Material
- Steel
- Black
AV Furniture
- Bracket
- Recommended Use
- Flat panel
- Placing / Mounting
- Ceiling mountable
- 32"-75"
- Tilt
- 0° to 25°
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 50 kg
- Limited warranty - 5 years
- Designed For
- P/N: HDMIPLATE
StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter | In Stock | £32.94 |
StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable | In Stock | £5.45 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.75 |
StarTech.com Ceiling TV Mount - Steel | In Stock | £101.75 |
StarTech.com Ceiling TV Mount - Long Pole | In Stock | £136.15 |
StarTech.com 10m CL2 Active HDMI Cable - 4K | In Stock | £81.45 |
StarTech.com Ceiling TV Mount, Back-to-Back | In Stock | £209.05 |
