StarTech.com Ceiling TV Mount, Back-to-Back
Quicklinx: F2KDWS00 Mfr#: FPCEILBTB
Type: Bracket
Hurry, only 2 left in stock!
£209.05 ex VAT
£250.86 inc VAT
Create impressive and effective digital signage with this ceiling TV mount, suspending two 32" to 75" TVs, back-to-back. Ideal for open spaces in retail, hospitality, restaurants and many other areas, the dual-screen mount provides a versatile way to inform customers, and doubles the audience viewing your content.
The dual-screen mount securely holds two flat-screen TVs back to back, in landscape position. The steel mount supports VESA mount displays up to 600 x 400 mm) with a weight capacity of 99 lb. (45 kg) per display.
With a telescopic pole, the ceiling TV mount lets you suspend two displays at your desired distance from the ceiling, working with a range of ceiling heights. The pole-mount TV bracket can extend from 41.7" to 61.4" (1060 to 1560 mm), with a total lift (height extension) of 19.7" (500 mm).
For optimum viewing, the mount lets you swivel the display+180/-180 degrees around the pole. The free-tilting design lets you adjust the tilt angle +5/-20 degrees.
The dual-display mount accommodates a wide variety of ceiling types. Swivel the ceiling TV mount to work with virtually any type of ceiling for level viewing, including sloped ceilings (up to 60 degrees) or horizontal (flat) ceilings.
The ceiling mount provides a hook-and-mount design for easy setup. The wire-management channels keep cables concealed.
  • Back-to-Back TV Mount
    The dual-screen mount securely holds two flat-screen TVs back to back, in landscape position. The steel mount supports VESA mount displays up to 600 x 400 mm with a weight capacity of 110 lb. (50 kg) per display.
  • Adjustable Height
    With a telescopic pole, the ceiling TV mount lets you suspend two displays at your desired distance from the ceiling, working with a range of ceiling heights. The pole-mount TV bracket can extend from 41.7" to 61.4" (1060 to 1560 mm) from the ceiling, with a total lift (height extension) of 19.7" (500 mm).
  • Easy Screen Adjustment
    For optimum viewing, the mount lets you swivel the display 360 degrees around the pole. The free-tilting design lets you adjust the tilt angle +5/-20 degrees.
  • Swivels to Suit Your Ceiling
    The dual-display mount accommodates a wide variety of ceiling types. Swivel the ceiling TV mount to work with virtually any type of ceiling for level viewing, including sloped ceilings (up to +/-60 degrees) or horizontal (flat) ceilings.
  • Simple Setup and Cable Management
    The ceiling mount provides a hook-and-mount design for easy setup. The wire-management channels keep cables concealed. The +/-3 degree post-installation leveling adjustments ensure ideal positioning after hanging. FPCEILBTB is backed by a StarTech.com 5-year warranty and free lifetime technical support.
StarTech.com Dual TV Ceiling Mount, Back-to-Back Heavy Duty Hanging Dual Screen Mount with Adjustable Telescopic 3.5' to 5' Pole, Tilt/Swivel/Rotate, VESA Bracket for 32”-75" Displays - Ceiling TV Bracket (FPCEILBTB) bracket - for flat panel - black
Bracket - ceiling mountable
43.5 cm x 68 cm
Tilt
-5° to 20°
Pan
-180° to 180°
Lift
50 cm
Rotation
360°
Swivel
-60° to 60°
Adjustments
Height, pan, tilt, swivel, rotation
Recommended Use
Flat panel
Recommended Display Size
32"-75"
VESA Mounting Interface
200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Load Weight
45 kg
Material
Heavy duty steel
Package Content
4 x concrete anchors, hex key, wrench, ceiling mount and pole, lower pole, TV mount, 2 x M8x55 screws, mounting template, 2 x nuts, 8 x M5x14 screws, 4 x vertical brackets, 2 x horizontal brackets, 8 x M6x14 screws, 8 x M6x30 screws, 8 x M8x30 screws, 8 x M8x50 screws, 8 x rectangular washers, 4 x round washers, 16 x spacers (small), 16 x spacers (large), 4 x ceiling mounting screws
5-year warranty
43.5 cm
68 cm
Material
Heavy duty steel
Package Content
AV Furniture
Bracket
Recommended Use
Flat panel
Placing / Mounting
Ceiling mountable
Cable Management
Integrated cable management
32"-75"
Tilt
-5° to 20°
Pan
-180° to 180°
Lift
50 cm
Rotation
360°
Swivel
-60° to 60°
Adjustments
Max Load Weight
45 kg
Dimensions & Weight Details
10.8 kg
Limited warranty - 5 years
F2KD StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.65
F2KD StarTech.com Flat-Screen TV Ceiling Mount In Stock £109.26
F2KD StarTech.com Ceiling TV Mount - Steel In Stock £101.75
F2KD StarTech.com Ceiling TV Mount - Long Pole In Stock £136.15
F2KD StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £79.63
Type: Bracket
