StarTech.com Fiber Breakout Cable 10m MPO / MTP to LC
Quicklinx: DXF1WS00 Mfr#: MPO8LCPL10M
Length: 10m
Colour: Aqua
10 In Stock
£75.51 ex VAT
£90.61 inc VAT
Fan out eight fibers from a 40Gbps MPO connection to four 10Gbps LC connections. This MPO/MTP to 8x LC breakout cable lets you fan out a single 40Gbps connection from a 40GBase-SR4 QSFP+ transceiver to four 10Gbps LC SFP+ transceivers.
The push-and-pull tabs optimize accessibility and let you install or remove the connectors with one hand without using additional tools. Plus, the slim uniboot design of the LC connectors saves space and improves cable management.
The MPO cable is housed in a plenum-rated jacket and is ideal for in-wall installations or anywhere CMP fire rating is required.
Each OM3 fiber cable has been individually tested for insertion loss and return loss. The full test report is included in each cable bag.
  • Reliable connectivity
    This MTP to LC Breakout Cable utilizes a fiber optic design to ensure dependable communication and data transfer in network setups.
  • Versatile connector types
    The cable features MTP/MPO multi-mode connectors on one end and LC multi-mode connectors on the other, allowing for a diverse range of applications.
  • Compliance assurance
    Constructed in compliance with OM3 standards and RoHS regulations, this cable promotes safety and environmental responsibility in networking solutions.
  • Efficient core/cladding specifications
    With a core/cladding diameter of 50 / 125 micron, this multimode fiber optic cable delivers optimal performance for various networking tasks.
  • Easy installation process
    The push/pull design of the connectors simplifies the connection process, enabling fast and reliable setup without complications.
StarTech.com MTP to LC Breakout Cable - 30 ft / 10m - OM3 Multimode - 40Gb - Pull Tab - Plenum - MPO / MTP Connector - Fiber Optic Cable (MPO8LCPL10M) - breakout cable - 10 m - aqua
Breakout cable - OM3
Fibre optic
Type of Fibre Optics
Multimode
Plenum
Length
10 m
Core / Cladding Diameter
50 / 125 micron
Connector
MTP/MPO multi-mode - female - push/pull
Connector (Second End)
8 x LC multi-mode - male - push/pull
Aqua
Network Cable Type
Fibre optic
Multimode
50 / 125 micron
Plenum
Length
10 m
91.4 g
Aqua
Connector
RoHS
DXF1 StarTech.com Fiber Breakout Cable 10m MPO / MTP to LC In Stock £75.51
Length: 10m
Colour: Aqua
