This Ethernet fiber media converter offers an easy, cost-effective way to extend your network over fiber, using the SFP+ of your choice. It converts a copper RJ45 Ethernet connection to 10 Gigabit fiber, to extend your network over longer distances or connect workstations to switches.
The RJ45 to fiber media converter provides a cost-efficient way to connect an Ethernet network to remote devices over a fiber backbone. It features an open SFP+ slot that supports the MSA-compliant 10 Gigabit SFP+ that best suits your fiber connection setup (single mode/multimode) and distance requirements.
The 10Gb fiber media converter supports auto-negotiation while providing versatile connectivity to existing networks and devices, maximizing the usage and performance of legacy equipment.
Network Compatibility: 10GBASE-ER; 10GBASE-LR; 10GBASE-LW; 10GBASE-EW; 10GBASE-R; 10GBASE-SR; 10GBASE-SW; 10GBASE-T.
The unmanaged fiber media converter has a standalone compact design with simple plug-and-play setup to ensure fast and easy installation.
Overcome the distance limitations of traditional network cables with StarTech.com fiber media converters. The converters connect different types of network cabling and help you extend networks between buildings and over longer distances. Whether you need to extend a network connection 550 m or 40 km, StarTech.com can help you.
Cost-Effective Extensions and Flexible Performance
The RJ45 to fiber media converter provides a cost-efficient way to connect an Ethernet network to remote devices over a fiber backbone. It features an open SFP+ slot that supports the MSA-compliant 10 Gigabit SFP+ that best suits your fiber connection setup (single mode/multimode) and distance requirements. -
A Versatile Way to Connect Different Networks
The 10Gb fiber media converter supports auto-negotiation while providing versatile connectivity to existing networks and devices, maximizing the usage and performance of legacy equipment. -
• 10GBASE-ER • 10GBASE-LR • 10GBASE-LW • 10GBASE-EW • 10GBASE-R • 10GBASE-SR • 10GBASE-SW • 10GBASE-T -
Fast and Easy Installation
The unmanaged fiber media converter has a standalone compact design with simple plug-and-play setup to ensure fast and easy installation. -
StarTech.com Fiber Media Converters
Overcome the distance limitations of traditional network cables with StarTech.com fiber media converters. Our converters connect different types of network cabling and help you extend networks between buildings and over longer distances. Whether you need to extend a network connection 550 m or 40 km, we can help you. The MCM10GSFP Ethernet Fiber Media Converter is backed by a StarTech.com 2-year warranty and free North American based multilingual lifetime technical support.
- StarTech.com 10GbE Fiber Ethernet Media Converter for 10Gbps Network 10GBASE-T SFP to RJ45 Multigigabit Singlemode/Multimode Fiber Optic to Copper Network Ethernet to Fiber Bridge, SMF/MMF - SFP to RJ-45 Converter (MCM10GSFP) - fibre media converter - 10GbE
- Fibre media converter - RJ-45 / SFP+
- Form Factor
- External
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- Cabling Type
- 10GBase-LR, 10GBase-SR, 10GBase-T
- Data Transfer Rate
- 10 Gbps
- Data Link Protocol
- 10GbE
- 8 cm x 12.2 cm x 3 cm
- 274 g
- 2-year warranty
- Form Factor
- External
- Localisation
- Connectivity Technology
- Wired
- Cabling Type
- 10GbE
- 10 Gbps
- Status Indicators
- Power, link OK
- Auto-negotiation, auto-uplink (auto MDI/MDI-X), full duplex mode, 9 KB Jumbo Frame, VLAN Tagging
- IEEE 802.1Q, IEEE 802.3ae, IEEE 802.3an
- 1 x Ethernet 10GBase-T - RJ-45 , 1 x Ethernet 10GBase-LR/10GBase-SR - SFP+
- UL, FCC, RoHS, PSE Mark
- Power Device
- External power adapter
- 8 cm
- 12.2 cm
- 3 cm
- 274 g
- Shipping Weight
- 350 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 10 - 90%
