StarTech.com ESD Anti Static Wrist Strap
Quicklinx: C19YWS00 Mfr#: SWS100
44 In Stock
£7.62 ex VAT
£9.14 inc VAT
Standard delivery Delivered within 3-5 working days
Prevents dangerous electrostatic buildup while working on electronics. This durable ESD anti-static wrist strap helps you protect your valuable computer equipment from dangerous static electricity. The wrist strap/grounding bracelet offers hassle-free electrostatic grounding, allowing you to work freely on your computer without having to worry about static build-up, which could potentially damage computer components.
Designed and constructed to exceed IBM and US military static control standards, the grounding bracelet/ESD wrist strap is made from the highest quality static dissipative material to ensure the safe operation of your equipment.
  • Enhanced safety
    The ESD Anti Static Wrist Strap Band with Grounding Wire is designed to provide an essential layer of safety for PC users, effectively preventing electrostatic discharge during the handling of sensitive electronic components.
  • Easy to use
    This anti-static wrist band is straightforward and comfortable to wear, ensuring a secure fit and reliable grounding with its adjustable strap and grounding wire.
StarTech.com ESD Anti Static Wrist Strap Band with Grounding Wire - AntiStatic Wrist Strap - Anti-static wrist band (SWS100) - anti-static wrist band
1-year warranty
P/N: M3013
Limited warranty: - 1 year
P/N: M3013
C19Y StarTech.com ESD Anti Static Wrist Strap In Stock £7.62
C19Y StarTech.com Desktop Anti-Static Mat In Stock £19.88
