StarTech.com DVI to VGA Cable Adapter M/F - 10 pack
Quicklinx: B0N0WS00 Mfr#: DVIVGAMF10PK
Connect your VGA Display to a DVI-I source. The DVIVGAMF10PK 10-pack of DVI-I to VGA Adapters offers a cost-effective option when you have multiple DVI-enabled computers to connect to VGA monitors.
At a lower cost per unit, these DVI to VGA adapters convert DVI male connectors to VGA female connectors - a perfect solution for schools, and other organizations to connect DVI-I desktop or laptop computers to VGA monitors or projectors.
The adapters are constructed of high-quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your devices use a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter (DVI2VGACON).
StarTech.com DVI to VGA Cable Adapter - DVI (M) to VGA (F) - 10 Pack - White - Male DVI to Female VGA (DVIVGAMF10PK) - VGA adapter
VGA adapter
Packaged Quantity
10 (specifications are for single item)
Molded, thumbscrews
Connector
HD-15 (VGA) - female
Connector (Second End)
DVI-I - male
RoHS
Beige
Packaged Quantity
VGA adapter
Plated Connector
Nickel
Molded, thumbscrews
Beige
Connector
15 pin HD D-Sub (HD-15) - female
24+5 pin combined DVI - male
RoHS
