Connect your DVI-I Display to a VGA video card. The DVIVGAFM DVI to VGA Cable Adapter converts a DVI male connector to a VGA male connector, allowing you to connect devices with VGA output to a DVI input port.
The DVI to VGA cable adapter eliminates the expense of having to upgrade a VGA video source for the sake of compatibility with a newer DVI capable display.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
- StarTech.com DVI to VGA Cable Adapter - F/M - DVI to VGA connector - DVI to VGA Converter - DVI to VGA Adapter (DVIVGAFM) - VGA adapter
- VGA adapter
- Connector
- DVI-I - female
- Connector (Second End)
- HD-15 (VGA) - male
- FCC, RoHS
- Beige
- Limited lifetime warranty
- VGA adapter
- Beige
- Connector
- 24+5 pin combined DVI - female
- 15 pin HD D-Sub (HD-15) - male
- FCC, RoHS
|  | StarTech.com DVI to VGA Cable Adapter - Black - F/M | In Stock | £7.23 |
