StarTech.com DVI to VGA Cable Adapter - Black - F/M
Quicklinx: 7NXPWS00 Mfr#: DVIVGAFMBK
12 In Stock
£7.33 ex VAT
£8.79 inc VAT
Use your DVI-I Display with a VGA video card. The DVIVGAFMBK DVI-I to VGA Display Adapter (F/M) is used to convert a DVI male connector to a VGA male connector. The DVI to VGA adapter is constructed of high quality materials, to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer StarTech.com's DVI to VGA Converter DVI2VGACON.
StarTech.com DVI to VGA Cable Adapter - Black - F/M (DVIVGAFMBK) - VGA adapter
VGA adapter
Connector
DVI-I - female
Connector (Second End)
HD-15 (VGA) - male
P/N: BNDDKT30CAHV, USB31GEVG, USB3SMDOCKHV
VGA adapter
Connector
24+5 pin combined DVI - female
7NXP StarTech.com DVI to VGA Cable Adapter - M/F In Stock £5.17
7NXP StarTech.com DVI to VGA Cable Adapter - Black - M/F In Stock £3.87
