Brand
StarTech.com DVI to VGA Cable Adapter - F/M
Quicklinx: 4LCYWS00 Mfr#: DVIVGAFM
£7.13 ex VAT
£8.55 inc VAT
Connect your DVI-I Display to a VGA video card. The DVIVGAFM DVI to VGA Cable Adapter converts a DVI male connector to a VGA male connector, allowing you to connect devices with VGA output to a DVI input port.
The DVI to VGA cable adapter eliminates the expense of having to upgrade a VGA video source for the sake of compatibility with a newer DVI capable display.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
StarTech.com DVI to VGA Cable Adapter - F/M - DVI to VGA connector - DVI to VGA Converter - DVI to VGA Adapter (DVIVGAFM) - VGA adapter
VGA adapter
Connector
DVI-I - female
Connector (Second End)
HD-15 (VGA) - male
FCC, RoHS
Beige
VGA adapter
Beige
Connector
24+5 pin combined DVI - female
FCC, RoHS
4LCY StarTech.com DVI to VGA Cable Adapter - Black - F/M In Stock £7.71
Stock Status: In stock
