Connect your DVI-I Display to a VGA video card. The DVIVGAFM DVI to VGA Cable Adapter converts a DVI male connector to a VGA male connector, allowing you to connect devices with VGA output to a DVI input port.
The DVI to VGA cable adapter eliminates the expense of having to upgrade a VGA video source for the sake of compatibility with a newer DVI capable display.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
 - StarTech.com DVI to VGA Cable Adapter - F/M - DVI to VGA connector - DVI to VGA Converter - DVI to VGA Adapter (DVIVGAFM) - VGA adapter
 - VGA adapter
- Connector
 - DVI-I - female
- Connector (Second End)
 - HD-15 (VGA) - male
 - FCC, RoHS
 - Beige
 - Limited lifetime warranty
 - VGA adapter
 - Beige
- Connector
 - 24+5 pin combined DVI - female
 - 15 pin HD D-Sub (HD-15) - male
 - FCC, RoHS
                        StarTech.com DVI to VGA Cable Adapter - Black - F/M | In Stock | £7.23 |
