Connect your VGA Display to a DVI-I source. The DVIVGAMFBK DVI-I to VGA Adapter (M/F) is used to convert a DVI Male connector to a VGA female connector. The DVI to VGA adapter is constructed of high quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
Reliable connectivity
Equipped with a male 24+5 pin combined DVI connector and a female 15 pin HD D-Sub, this adapter allows for reliable connections between various devices. -
Durable design
Constructed with a molded design, this adapter withstands daily wear and tear, ensuring lasting performance. -
Secure attachment
The inclusion of thumbscrews facilitates secure attachment to prevent accidental disconnection during use.
- StarTech.com DVI to VGA Cable Adapter - Black - M/F - DVI-I to VGA Converter Adapter (DVIVGAMFBK) - VGA adapter
- VGA adapter
- Molded, thumbscrews
- Connector
- DVI-I - male
- Connector (Second End)
- HD-15 (VGA) - female
- RoHS
- Black
- Limited lifetime warranty
- VGA adapter
- Black
- Connector
- 24+5 pin combined DVI - male
- 15 pin HD D-Sub (HD-15) - female
- RoHS
StarTech.com DVI to VGA Cable Adapter - M/F | In Stock | £5.16 |
StarTech.com DVI to VGA Cable Adapter - Black - M/F | In Stock | £6.22 |
StarTech.com DVI to VGA Cable Adapter - Black - F/M | In Stock | £7.36 |
StarTech.com 8in DVI to VGA Cable Adapter - DVI-I Male to VGA Female | In Stock | £7.62 |
StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200 | In Stock | £22.78 |
StarTech.com DVI to VGA Cable Adapter M/F - Black - 10 Pack | In Stock | £26.82 |
