StarTech.com DVI to VGA Cable Adapter - M/F
Customer rating: 5.0* (Write a review)
Quicklinx: 3ZKQWS00 Mfr#: DVIVGAMF
10 left in stock
£5.17 ex VAT
£6.20 inc VAT
The DVIVGAMF DVI-I to VGA Display Adapter (M/F) is used to convert a DVI Male connector to a VGA female connector. The DVI to VGA adapter is constructed of high quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
  • Versatile compatibility
    This adapter connects devices with male DVI outputs to those with female VGA inputs, making it suitable for a variety of applications.
  • Reliable signal transmission
    Designed to maintain a strong connection, the adapter minimizes signal loss, ensuring clear and consistent picture quality.
StarTech.com DVI to VGA Cable Adapter - DVI (M) to VGA (F) - 1 Pack - Male DVI to Female VGA (DVIVGAMF) - VGA adapter
VGA adapter
Connector
DVI-I - male
Connector (Second End)
HD-15 (VGA) - female
Beige
P/N: MXT101MMHD15, MXT101MMHD6
VGA adapter
Beige
Connector
24+5 pin combined DVI - male
15 pin HD D-Sub (HD-15) - female
3ZKQ StarTech.com DVI to VGA Cable Adapter - M/F In Stock £5.17
3ZKQ StarTech.com DVI to VGA Cable Adapter - Black - M/F In Stock £3.88
3ZKQ StarTech.com DVI to VGA Cable Adapter - Black - F/M In Stock £7.23
3ZKQ StarTech.com 8in DVI to VGA Cable Adapter - DVI-I Male to VGA Female In Stock £7.63
3ZKQ StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200 In Stock £22.78
Customer reviews
Write a review for the StarTech.com DVI to VGA Cable Adapter - M/F here!
Good Stuff
Reviewed by M@ Morgan. Review Posted 20/01/2007
does what it say it should!! why not buy 2!?
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Does what it says!
Reviewed by Matt. Review Posted 14/02/2007
Very good adapter! High quality and does exactly what it says!
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Stock Status: While stocks last
Stock Status: Clearance
