StarTech.com DVI to VGA Cable Adapter - Black - M/F
Quicklinx: 7B5CWS00 Mfr#: DVIVGAMFBK
19 In Stock
£3.88 ex VAT
£4.65 inc VAT
Connect your VGA Display to a DVI-I source. The DVIVGAMFBK DVI-I to VGA Adapter (M/F) is used to convert a DVI Male connector to a VGA female connector. The DVI to VGA adapter is constructed of high quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
  • Reliable connectivity
    Equipped with a male 24+5 pin combined DVI connector and a female 15 pin HD D-Sub, this adapter allows for reliable connections between various devices.
  • Durable design
    Constructed with a molded design, this adapter withstands daily wear and tear, ensuring lasting performance.
  • Secure attachment
    The inclusion of thumbscrews facilitates secure attachment to prevent accidental disconnection during use.
StarTech.com DVI to VGA Cable Adapter - Black - M/F - DVI-I to VGA Converter Adapter (DVIVGAMFBK) - VGA adapter
VGA adapter
Molded, thumbscrews
Connector
DVI-I - male
Connector (Second End)
HD-15 (VGA) - female
RoHS
VGA adapter
Molded, thumbscrews
Connector
24+5 pin combined DVI - male
15 pin HD D-Sub (HD-15) - female
RoHS
7B5C StarTech.com DVI to VGA Cable Adapter - M/F In Stock £5.16
7B5C StarTech.com DVI to VGA Cable Adapter - Black - M/F In Stock £3.88
7B5C StarTech.com DVI to VGA Cable Adapter - Black - F/M In Stock £7.23
7B5C StarTech.com 8in DVI to VGA Cable Adapter - DVI-I Male to VGA Female In Stock £7.62
7B5C StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200 In Stock £22.78
