StarTech.com DVI to HDMI Video Converter with Audio
Quicklinx: 7S7ZWS00 Mfr#: DVI2HDMIA
  • High-Definition Multimedia Interface (HDMI)
The DVI2HDMIA DVI to HDMI Converter/Adapter lets you connect a DVI-D source with the accompanying RCA audio signal to an HDMI monitor or HDTV, with support for full HD 1080p (1920x1080) resolution.
A cost-effective alternative to upgrading equipment for compatibility, this small form factor adapter provides a plug-and-play solution for connecting your Mac, PC or home theater device with DVI (digital) output to your television or HDMI monitor. The RCA stereo audio connections integrate the audio signal directly into the HDMI output, so that a single cable can be run to your destination device.
StarTech.com DVI to HDMI Video Converter with Audio - Video converter - DVI - HDMI - black - DVI2HDMIA - video converter - black
Video converter
Max Resolution
1920 x 1080
1 x DVI-I input - 24+5 pin combined DVI , 1 x audio line-in - RCA x 2 , 1 x HDMI output - 19 pin HDMI Type A
2.6 cm x 8.8 cm x 6.8 cm
Enclosure Colour
1-year warranty
Video converter
Max Resolution
1920 x 1080
1 x DVI-I input - 24+5 pin combined DVI - female , 1 x audio line-in - RCA x 2 - female , 1 x HDMI output - 19 pin HDMI Type A - female
DC 5 V (50/60 Hz)
5 Watt
Plug and Play, FCC, RoHS
2.6 cm
8.8 cm
6.8 cm
200 g
Enclosure Colour
Limited warranty - 1 year
70 °C
10 - 85%
7S7Z StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.48
7S7Z StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.94
7S7Z StarTech.com 6in Stereo Audio Cable - 3.5mm Male to 2x RCA Female In Stock £4.25
7S7Z StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
7S7Z StarTech.com DVI to DisplayPort Adapter In Stock £25.49
