Connect a DVI-D equipped Laptop or Desktop Computer to your VGA Display, or Projector. The DVI2VGAE active DVI-D to VGA adapter lets you connect a digital DVI output from your desktop or laptop computer onto a VGA monitor or projector, saving the cost of upgrading to a DVI-D compatible display.
Providing a simple way to output user-generated content such as presentations and work documents, the DVI-D to VGA converter can also work to increase your productivity by extending your computer's desktop onto to a secondary monitor, doubling available workspace.
This portable adapter works to convert a standard powered DVI bus to VGA, without an external power source. For low-powered DVI ports, a USB cable is included that can power the device from any USB power source.
With support for resolutions up to 1920x1200 (WUXGA), this active adapter offers a comprehensive solution for connecting a High-Definition VGA display to a DVI-D video source.
- StarTech.com DVI-D to VGA Active Adapter Converter Cable - 1080p - DVI to VGA Converter box (DVI2VGAE) - video adapter - 24.8 m
- Video adapter
- Active adapter, 1920 x 1200 (WUXGA) support
- Length
- 24.8 m
- Connectors
- 24+1 pin digital DVI - male , 5 pin Micro-USB Type B (power only) - female
- Connectors (Second End)
- 15 pin HD D-Sub (HD-15) - female
- Black
- 3-year warranty
- Video adapter
- Jacket Material
- Plastic
- Length
- 24.8 m
- Black
- 4.5 cm
- 1.5 cm
- 77.1 g
- Connectors
- Included Accessories
- USB-A to micro-USB cable (61 cm)
- FCC, RoHS
- Shipping Width
- 20 cm
- Shipping Depth
- 8.8 cm
- Shipping Height
- 1.8 cm
- Shipping Weight
- 73.4 g
- 3-year warranty
StarTech.com DVI to VGA Cable Adapter - M/F | In Stock | £5.11 |
StarTech.com DVI to VGA Cable Adapter - Black - M/F | In Stock | £3.87 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male | In Stock | £9.05 |
StarTech.com DVI to DisplayPort Adapter | In Stock | £24.48 |
