Use this DVI to DisplayPort converter to connect your DVI computer to a DisplayPort monitor or projector. This DVI to DisplayPort adapter lets you connect a DVI video source, such as your desktop or laptop computer, to your DisplayPort (DP) monitor or projector.
The DVI to DisplayPort converter is USB powered, giving you the freedom to power it using a USB port on your computer, unlike some converters that require bulky external power adapters. USB power, combined with the adapter's small footprint and lightweight design promotes portability, ensuring the adapter can travel with your laptop. Plus, the adapter supports plug-and-play installation, ensuring you won't need to load any special drivers or software.
This cost-effective adapter enables DVI-D to DP conversion so you can connect your DVI computer to a DisplayPort monitor. This functionality is perfect for connecting legacy computer systems with DVI outputs to newer DVI monitors or projectors.
Using the DVI to DisplayPort adapter, you can connect a secondary monitor to your laptop. The added screen space makes it easier to multitask, enabling you to work more efficiently and accomplish more in less time. It's perfect for office use, or wherever you view documents, spreadsheets, and web pages across multiple screens.
With support for display resolutions up to 1920x1200 or 1080p, the DVI to DisplayPort adapter lets you take full advantage of the single-link DVI-D capabilities that are built into your computer's graphics card.
Versatile connectivity
The DVI to DisplayPort Adapter enables a connection from a male DVI source to a female DisplayPort monitor, facilitating compatibility between different video interfaces. -
High video resolution
Supports a resolution of up to 1920 x 1200, ensuring sharp and clear image quality for various applications, from presentations to high-definition video playback. -
Enhanced performance
Utilizes dual link TMDS technology to provide greater bandwidth and improved resolution, delivering vibrant and detailed visual output. -
Convenient power source
Equipped with USB power capability, this adapter can be powered easily from a USB source, eliminating the need for additional power adapters. -
Effortless setup
With Plug-and-Play compliance, users can easily connect devices without the hassle of software installation or complex configuration.
- StarTech.com DVI to DisplayPort Adapter - USB Power - 1920 x 1200 - DVI to DisplayPort Converter - Video Adapter - DVI-D to DP (DVI2DP2) - video adapter - DVI-D to DisplayPort
- Video adapter - dual link
- USB power
- Connector
- 24+1 pin digital DVI - male
- Connector (Second End)
- 20 pin DisplayPort - female
- 2-year warranty
- Video adapter
- TMDS Links
- Dual link
- USB power
- Connector
- Plug and Play
- 2-year warranty
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.05 |
StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200 | In Stock | £24.01 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.12 |
