StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200
Quicklinx: 8RQRWS00 Mfr#: DVI2VGAE
Type: A/V
Length: 24.8m
£22.98 ex VAT
£27.57 inc VAT
Connect a DVI-D equipped Laptop or Desktop Computer to your VGA Display, or Projector. The DVI2VGAE active DVI-D to VGA adapter lets you connect a digital DVI output from your desktop or laptop computer onto a VGA monitor or projector, saving the cost of upgrading to a DVI-D compatible display.
Providing a simple way to output user-generated content such as presentations and work documents, the DVI-D to VGA converter can also work to increase your productivity by extending your computer's desktop onto to a secondary monitor, doubling available workspace.
This portable adapter works to convert a standard powered DVI bus to VGA, without an external power source. For low-powered DVI ports, a USB cable is included that can power the device from any USB power source.
With support for resolutions up to 1920x1200 (WUXGA), this active adapter offers a comprehensive solution for connecting a High-Definition VGA display to a DVI-D video source.
StarTech.com DVI-D to VGA Active Adapter Converter Cable - 1080p - DVI to VGA Converter box (DVI2VGAE) - video adapter - 24.8 m
Video adapter
Active adapter, 1920 x 1200 (WUXGA) support
Length
24.8 m
Connectors
24+1 pin digital DVI - male , 5 pin Micro-USB Type B (power only) - female
Connectors (Second End)
15 pin HD D-Sub (HD-15) - female
3-year warranty
Video adapter
Jacket Material
Plastic
Length
24.8 m
4.5 cm
1.5 cm
77.1 g
Connectors
USB-A to micro-USB cable (61 cm)
FCC, RoHS
Shipping Width
20 cm
Shipping Depth
8.8 cm
Shipping Height
1.8 cm
Shipping Weight
73.4 g
3-year warranty
8RQR StarTech.com DVI to VGA Cable Adapter - Black - M/F In Stock £3.87
8RQR StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male In Stock £9.26
8RQR StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200 In Stock £22.98
8RQR StarTech.com DVI to DisplayPort Adapter In Stock £25.49
Type: A/V
Length: 24.8m
