StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200
Quicklinx: 8RQRWS00 Mfr#: DVI2VGAE
Type: A/V
More than 50 in stock
£23.87 ex VAT
£28.64 inc VAT
Connect a DVI-D equipped Laptop or Desktop Computer to your VGA Display, or Projector. The DVI2VGAE active DVI-D to VGA adapter lets you connect a digital DVI output from your desktop or laptop computer onto a VGA monitor or projector, saving the cost of upgrading to a DVI-D compatible display.
Providing a simple way to output user-generated content such as presentations and work documents, the DVI-D to VGA converter can also work to increase your productivity by extending your computer's desktop onto to a secondary monitor, doubling available workspace.
This portable adapter works to convert a standard powered DVI bus to VGA, without an external power source. For low-powered DVI ports, a USB cable is included that can power the device from any USB power source.
With support for resolutions up to 1920x1200 (WUXGA), this active adapter offers a comprehensive solution for connecting a High-Definition VGA display to a DVI-D video source.
StarTech.com DVI-D to VGA Active Adapter Converter Cable - 1080p - DVI to VGA Converter box (DVI2VGAE) - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DVI-D input - 24+1 pin digital DVI , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 5 pin Micro-USB Type B , 1 x USB - 4 pin USB Type A (on supplied cable)
4.5 cm x 25 cm x 1.5 cm
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DVI-D input - 24+1 pin digital DVI - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x USB - 5 pin Micro-USB Type B - female , 1 x USB - 4 pin USB Type A (on supplied cable) - male
USB powered
1 x micro-USB to USB cable
FCC, RoHS
4.5 cm
25 cm
1.5 cm
75 g
Enclosure Colour
Limited warranty - 3 years
8RQR StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.82
8RQR StarTech.com 6 ft DVI-D Single Link Cable - M/M In Stock £6.86
8RQR StarTech.com HDMI to DVI-D Video Cable Adapter - F/M In Stock £7.55
8RQR StarTech.com High Resolution Video DVI to VGA Converter In Stock £86.89
8RQR StarTech.com 3 ft HD15 to Component RCA Breakout Cable Adapter - M/M In Stock £10.17
8RQR StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male In Stock £7.43
8RQR StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200 In Stock £23.87
8RQR StarTech.com 3 ft DVI to VGA Active Converter Cable – DVI-D to VGA Adapter – 1920x1200 In Stock £25.72
8RQR StarTech.com 6 ft DVI to VGA Active Converter Cable – DVI-D to VGA Adapter – 1920x1200 In Stock £29.41
Type: A/V
Price Range Ex VAT: 0 - 50
