StarTech.com Dual Sit Stand Desk/Wall Mount
Quicklinx: DBT6WS00 Mfr#: WALLSTS2
Hurry, only 2 left in stock!
£283.91 ex VAT
£340.69 inc VAT
Easily convert your dual monitor workstation into a standing desk for greater comfort and productivity. This wall-mounted sit-stand desk for dual monitors is perfect for areas that don't have enough space for a traditional sit-stand desk. Its compact, wall-mounted design combines a dual-monitor arm and a keyboard tray, with easy height adjustments that let you alternate between sitting and standing without disrupting your workflow.
Adjust your working position in one smooth motion. Simply lift the work surface up to 17.2" (436 mm), to elevate your monitor, keyboard and mouse. The monitor mount has a separate height adjustment of up to 4.9" (124 mm) along the column.
This sit-stand monitor arm supports two monitors up to 24" (with weight capacity of 17.6 lb./8 kg). Adjust your monitor for ideal viewing, with -15° to +15° swivel and 0° to 30° tilt, or rotate your monitors up to 360° for portrait or landscape orientation.
The sit-stand desk folds back to the wall, and the keyboard tray folds up to 90°, saving space when not in use. You can move the swing arm left or right (from -90° to 90°) and lower or raise the arm (from -30° to 65°) to make maximum use of your space.
The monitor arm offers plenty of work space, with a large keyboard tray (17.68 x 8.15"/ 449 x 207 mm) and a slide-out tray (8.5 x 8.4" / 217 x 213 mm) that holds your mouse, on the left or right.
StarTech.com Sit Stand Dual Monitor Arm - For 2 x 24in Monitors - Height Adjustable - VESA Dual Monitor Stand - Sit Stand Workstation (WALLSTS2) - mounting kit
Mounting kit
Mounting Components
Wall plate, column, 2 crossbars, keyboard tray, monitor arm, 2 x VESA monitor mounts, crossbar mount
119.4 cm x 95.8 cm x 92.6 cm
Tilt
0° to 30°
Pan
-90° to 90°
Rotation
360°
Adjustments
10.3 kg
Recommended Use
2 monitors
Recommended Display Size
24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Material
Plastic, aluminium, steel
Image Colour Disclaimer
The displayed product image may be a different colour
Package Content
4 x washers, 4 x concrete anchors, 4 x M6x12 screws, hex key (5mm), wrench, hex key (2.5mm), hex key (6mm), wall plate, adhesive strip, socket driver, M8x20 screw, 3 x M6x10 screws, VESA monitor mount, 4 x mounting screws, 2 x M6x8 screws, 8 x M4x10 screws
119.4 cm
95.8 cm
92.6 cm
10.3 kg
Material
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
2 monitors
Cable Management
Integrated cable management
24"
Tilt
0° to 30°
Pan
-90° to 90°
Rotation
360°
Adjustments
Dimensions & Weight Details
Dimensions
Keyboard tray - width: 44.9 cm, depth: 20.7 cm
StarTech.com Dual Sit Stand Desk/Wall Mount Bundle deal on StarTech.com Dual Sit Stand Desk/Wall Mount
£383.08
DBT6 StarTech.com Sit Stand Monitor Arm In Stock £213.47
DBT6 StarTech.com Sit Stand Dual Monitor Arm In Stock £279.49
DBT6 StarTech.com Wall Mounted Sit Stand Desk In Stock £258.08
DBT6 StarTech.com Dual Sit Stand Desk/Wall Mount In Stock £283.91
Price Range Ex VAT: 150 - 300
