Quicklinx: DBT2WS00 Mfr#: ARMSTSCP1
Hurry, only 2 left in stock!
£421.75 ex VAT
£506.10 inc VAT
Enjoy a more ergonomic workspace with this sit-stand desk mount. This sit-stand monitor arm transforms your desk or tabletop into an ergonomic workstation. The monitor arm features a keyboard tray and easy height adjustment that lets you alternate between sitting and standing, without interrupting your workflow. Move your workstation up or down, left or right, to meet your needs.
Adjust your position, with one smooth motion. Simply lift the work surface up to 17.7" (450 mm), to elevate both your monitor and keyboard. You can adjust the tension to your own preference. The monitor mount has a separate height adjustment of up to 4.9" (124 mm) along the column.
This sit-stand monitor arm supports one monitor up to 24". The swing arm swivels from -90° to 90° and tilts from -30° to 65° for ideal viewing. The VESA mount also rotates up to 360° for portrait or landscape orientation.
The monitor arm features a large keyboard tray (17.68 x 8.15"/ 449 x 207 mm) with ample working space. A slide-out tray (8.5 x 8.4" / 217 x 213 mm) holds your mouse, on the left or right.
To make the most of your workspace, you can tuck the monitor arm away when it's not in use, to free up space. The keyboard tray also folds up to 90°.
The compact sit-stand monitor arm features a grommet assembly and desk-clamp option, to fit easily into your workspace, including space-limited corners.
  • Adjust the height with one smooth motion
  • Optimum adjustability
    This sit-stand monitor arm supports one monitor up to 27" (or 34" ultrawide). The swing arm swivels +/-90° and tilts +35°/ -5°for ideal viewing. The VESA mount also rotates up to 360° for portrait or landscape orientation.
  • Ample working space
    The monitor arm features a large keyboard tray (17.68 x 8.15"/ 449 x 207 mm) with ample working space. A slide-out tray (8.5 x 8.4" / 217 x 213 mm) holds your mouse, on the left or right. To make the most of your workspace, you can tuck the monitor arm away when it's not in use, to free up space. The keyboard tray also folds up to 90°.
  • Flexible installation
    The compact sit-stand monitor arm features a grommet assembly and desk-clamp option, to fit easily into your workspace, including space-limited corners. The ARMSTSCP1 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Sit Stand Monitor Arm, Desk Mount Adjustable Sit-Stand Workstation Arm for Single 34" VESA Mount Display, Ergonomic Articulating Standing Desk Converter with Keyboard Tray - Stand Up Office Desk (ARMSTSCP1) mounting kit - for monitor / keyboard
Mounting kit - desktop
Mounting Components
Base plate, column, grommet plate, keyboard tray, washers, monitor arm, clamp bracket, base, base pad
94 cm x 89 cm
Tilt
-30° to 65°
Pan
-90° to 90°
Lift
43.9 cm
Rotation
360°
Adjustments
Recommended Use
Monitor / keyboard
Recommended Display Size
Up to 24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
7.9 kg
Package Content
4 x M6x12 screws, hex key (5mm), hex key (2.5mm), hex key (6mm), 2 x M6x25 screws, adhesive strip, socket driver, clamp screws, clamp screw assembly, 4 x base screws, M8x20 screw, 3 x M6x10 screws, 4 x M4x10 screws, M6x8 screw, M8x65 screw, VESA monitor mount
P/N: LAPTOP-SIT-STAND
94 cm
89 cm
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Monitor / keyboard
Placing / Mounting
Desktop
Cable Management
Integrated cable management
Up to 24"
Tilt
-30° to 65°
Pan
-90° to 90°
Lift
43.9 cm
Rotation
360°
Adjustments
Max Load Weight
7.9 kg
DBT2 StarTech.com Sit-to-Stand Workstation In Stock £275.96
DBT2 StarTech.com Wall Mounted Sit Stand Desk In Stock £359.74
