Charge your tablet and your cell phone simultaneously, in your car. The USB2PCARBK Dual Port USB Car Charger features two USB 2.0 ports and works with any standard car AUX power outlet, enabling you to charge two mobile devices simultaneously while you commute for work or play.
With a 1A port for charging your Smartphone or iPhone, and a 2.4A port for charging your iPad or other tablet, you can always be sure you have the correct charge available for all your mobile devices. Having the second USB charge port available means you can charge two phones simultaneously and even make sure both you and your passenger are fully charged and ready to go. Plus, your passenger can charge and text, work or game while their device is charging.
- StarTech.com Dual-port USB car charger - 17W/3.4A - black car power adapter - USB - 17 Watt
- Product Type
- Car power adapter
- 42 g
- Black
- Output Connector Type
- Total 2: USB
- Voltage Required
- 12 - 24 V
- Voltage Provided
- 5 V
- Max Electric Current
- 3.4 A
- Power Provided
- 17 Watt
- 2-year warranty
- Designed For
- P/N: USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
- Product Type
- Car power adapter
- Designed For
- Tablet, mobile phone
- 42 g
- Enclosure Colour
- Black
- Voltage Required
- 12 - 24 V
- Input Connectors
- Automobile cigarette lighter
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- Total 2: 4 pin USB Type A
- Power Provided
- 17 Watt
- 3.4 A
- Limited warranty - 2 years
- Designed For
StarTech.com 2x USB Car Charger 24W / 4.8A | In Stock | £12.51 |
