StarTech.com 4-Port USB-C Charger, 240W
Quicklinx: J4KBWS00 Mfr#: 424DUK-USB-C-CHARGER
39 In Stock
£137.09 ex VAT
£164.50 inc VAT
The 240W USB-C GaN Desk Charger offers a high-power charging solution for USB-C devices, supporting up to 240W with PD 3.1. It includes a 6ft NEMA 5-15P to IEC-C5 Power Cord and a Charger Base. The charger does not include a USB-C cable, allowing flexibility in cable choice. It features 4 USB-C ports (one 140W EPR) to charge up to four laptops simultaneously, supporting high-performance devices like M-Series MacBook Pros. The charger ensures optimal cooling, fast charging (0-50% in 30 minutes), and efficiency with Active Power Factor Correction. It is USB-IF protocol compatible, TUV Safety Listed, and FCC/ICES EMC certified, meeting DOE Level VI standards. Ideal for various settings, it consolidates chargers and frees up desk space. The packaging is eco-friendly, designed to minimize environmental impact.
  • High capacity charging
    With a power output of 240 watts, this charger supports fast charging for multiple devices, ensuring quick and efficient power delivery.
  • Comprehensive safety features
    Includes overheat protection, overvoltage protection, and over-current protection, providing a safe charging environment for all connected devices.
  • Versatile connectivity
    Features four 24-pin USB-C output connectors, allowing charging of multiple devices simultaneously without compromising performance.
  • Space-saving design
    Incorporates GaN technology that reduces the charger's size while maintaining high power output, enhancing portability.
  • Multiple security options
    Equipped with Kensington and Noble Wedge security slots, ensuring devices can be securely attached and protected in various environments.
StarTech.com 4-Port USB-C Charger, 240W Total, Single Port 140W EPR power adapter - with surface mount bracket - 24 pin USB-C - 240 Watt
Power adapter
Notebook, tablet, mobile phone
800 g
United Kingdom
Output Connector Type
Total 4: 24 pin USB-C
AC 100-240 V
Voltage Provided
5 / 9 / 12 / 15 / 20 / 28 V
Max Electric Current
5 A
Fast Charge Technology
Power Delivery 3.1
Power Provided
240 Watt
Power Device Details
AC power adapter: 4 x - 24 pin USB-C - 140 W
Cables
Power cable (BS 1363 to IEC-C5) - 1.8 m
Power adapter
800 g
United Kingdom
AC 100-240 V
Input Connectors
Power BS 1363
Input Connectors Qty
1
Voltage Provided
Output connectors
Power Provided
240 Watt
5 A
AC power adapter: 4 x 24 pin USB-C - 140 W
Power Delivery 3.1
Screw lock system, GaN Technology, VESA 100 x 100 mm, over-current protection, overheat protection, over voltage protection, Kensington security slot, Noble Wedge security slot, Kensington Nano security slot, Programmable Power Supply (PPS), rubber feet
Material
Plastic
Mounting plate, 4 x M3x4 mm screw, 4 x M4x12 mm screw, 4 x M4x20 mm screw
Power Delivery (EPR), PSE Mark, RCM, RoHS, UL, WEEE, cULus, DoE Level VI, FCC, IEC 62368-1, USB-IF
Shipping Width
18.5 cm
Shipping Depth
17.4 cm
Shipping Height
5.8 cm
Shipping Weight
1.1 kg
J4KB StarTech.com 1.6ft USB4 Cable, USB-C 40Gbps In Stock £18.91
