StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter
Quicklinx: 9D6YWS00 Mfr#: 25SAT22MSAT
Hurry, only 1 left in stock!
£33.73 ex VAT
£40.47 inc VAT
Build a RAID array with two mSATA SSDs that can be installed into a single 2.5in SATA bay. Vastly increase system performance by adding a dual mSATA SSD RAID array into any 2.5" SATA HDD application with the 25SAT22MSAT mSATA to SATA adapter.
Utilize the full potential of your SATA III controller, with mSATA SSDs reducing your Data transfer bottleneck with file transfer speeds up to 6 Gbps. mSATA SSDs also save you money by reducing your power consumption over regular platter drives.
You can achieve greater SSD capacity, or data redundancy with the Dual SSD controller supporting multiple RAID modes (RAID 0, 1, BIG). The SSD adapter also supports non-RAID operation (JBOD) when paired with a port-multiplying SATA controller, so both drives can be used independent of one another.
Help protect the health of your drive with an open-frame design ensuring maximum heat dissipation.
StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter - 2x mSATA SSD to 2.5in SATA Adapter with RAID and 7mm Open Frame Housing (25SAT22MSAT) - storage controller - mSATA - SATA 6Gb/s
Storage controller - internal
Bus Type
SATA 6Gb/s
mSATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Channel Qty
2
RAID Level
RAID 0, RAID 1, JBOD, BIG
7 cm x 10 cm x 0.7 cm
40 g
P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F
Host Bus
SATA 6Gb/s
Storage Controller
mSATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Channel Qty
2
RAID Level
2 x - mSATA
1 x SATA 6Gb/s - 15 pin Serial ATA power
Mounting Kit
Included
FCC, RoHS
7 cm
10 cm
0.7 cm
40 g
-40 °C
85 °C
9D6Y StarTech.com 24" Serial ATA Cable In Stock £5.16
9D6Y StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
9D6Y StarTech.com 18in SATA Serial ATA Data and Power Combo Cable In Stock £5.76
9D6Y StarTech.com 18in SATA Serial ATA Cable In Stock £4.44
9D6Y StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.06
9D6Y StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.36
9D6Y StarTech.com 12in Latching SATA Cable In Stock £6.10
9D6Y StarTech.com 12in SATA Serial ATA Cable In Stock £4.46
9D6Y StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M In Stock £5.79
9D6Y StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.14
9D6Y StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable In Stock £3.92
9D6Y StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £29.24
9D6Y StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.12
9D6Y StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.52
9D6Y StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £33.73
9D6Y StarTech.com Dual M.2 NGFF SATA Adapter w/ RAID - 2x M.2 SSDs to 2.5in SATA In Stock £30.11
9D6Y StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.59
9D6Y StarTech.com M.2 to U.2 Adapter In Stock £22.89
9D6Y StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe In Stock £129.01
9D6Y StarTech.com 18in Right Angle SATA Cable In Stock £4.22
Type: Storage controller
