Save space by mounting two LCD or LED displays, up to 24" in size, onto a single low-profile base. This dual-monitor stand lets you mount two individual displays, each up to 24" in size, to a single base that you can place in virtually any workspace.
With its dual-crossbar design, this monitor stand lets you mount two monitors in the same physical space as one, so you have more surface area on your desk available for additional hardware or completing physical tasks such as drafting or reading paper documents. The monitor stand features a low-profile flat back that enables you can snugly position your displays against a wall or cubicle, unlike other dual-monitor mounting options.
If you're outfitting an entire office, you can give employees more work space at each desk and use smaller cubicles to maximize your available office real estate.
Adding two monitors to a single computer gives you the additional screen space you need to simplify multitasking and maximize your productivity. Using two displays makes it easier to reference material on one display while working on another, saving you the time and hassle of having to flip back and forth between documents.
The dual-monitor mount features easy-to-adjust height and tilt mechanisms, so you can customize the positioning of your displays to the most comfortable positions without disrupting your work. Plus, the desktop stand enables a hassle-free setup that ensures even installation is comfortable.
Versatile display support
This monitor mount accommodates screens ranging from 12" to 24", making it suitable for various display sizes. -
Flexible adjustments
Features such as height adjustments and tilt capabilities enable users to adapt the monitor to their preferred viewing position. -
Secure and sturdy design
Constructed from aluminum and steel, this stand provides the reliability needed to support monitors up to 8 kg. -
Organized cable management
The integrated cable management system helps to reduce clutter, maintaining a clean workspace. -
Easy assembly
The product includes essential components for setup, making it user-friendly for quick installation.
- StarTech.com Dual Monitor Mount - Supports Monitors 12" to 24" - Adjustable - VESA Monitor Stand for Desk - Low Profile Base - Horizontal - Black (ARMBARDUO) stand - adjustable arm - for LCD display - black
- Product Type
- Stand (adjustable arm) - stand mountable
- 95 cm x 18 cm x 41 cm
- Rotation
- 360°
- Adjustments
- Height, tilt
- 6.2 kg
- Recommended Use
- LCD display
- Recommended Display Size
- 24"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8 kg
- Material
- Plastic, aluminium, steel
- Black
- Package Content
- Pole, baseplate, 3 x M6x15 screws, cable-management clip (pole), pole cap, height-adjustment ring, crossbar, 2 x VESA monitor mounts, 8 x M4x12 screws, 8 x M4x30 screws, 8 x plastic spacers, allen wrench (3mm), allen wrench (4mm), 2 x cable-management clips (crossbar)
- 5-year warranty
- Designed For
- P/N: ACCSMNT, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, PXT101YUK, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV
- 95 cm
- 18 cm
- 41 cm
- 6.2 kg
- Material
- Black
- Package Content
AV Furniture
- Stand
- Design
- Adjustable arm
- Recommended Use
- LCD display
- Placing / Mounting
- Stand mountable
- Cable Management
- Integrated cable management
- 24"
- Rotation
- 360°
- Adjustments
- Height, tilt
- Max Load Weight
- 8 kg
- Adjustable Feet
- Assembly Required
- Limited warranty - 5 years
- Designed For
StarTech.com Universal USB 3.0 Laptop Docking Station Dual-Monitor HDMI DVI | In Stock | £65.29 |
StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio | In Stock | £62.58 |
StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video | In Stock | £48.91 |
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £135.75 |
StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort | In Stock | £82.53 |
StarTech.com Monitor Mount - USB Passthrough | In Stock | £157.69 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £213.39 |
StarTech.com Dual Monitor Stand | In Stock | £80.12 |
StarTech.com Vertical Dual Monitor Stand | In Stock | £79.68 |
StarTech.com Dual 4K Docking Station, Mac & Windows - USB-A & USB-C Dock, Dual 4K60 DP & HDMI | In Stock | £134.78 |
StarTech.com Thin Client Mount - VESA | In Stock | £22.48 |
StarTech.com Under Desk Keyboard Tray | In Stock | £52.06 |
StarTech.com USB-C Multiport Adapter Docking Station | In Stock | £118.27 |
StarTech.com Vertical Dual Monitor Stand | In Stock | £103.40 |
StarTech.com Dual Monitor Stand - Articulating - For Monitors up to 32" | In Stock | £131.53 |
StarTech.com Dual-Monitor Stand - Horizontal - For up to 24" Monitors - S | In Stock | £82.81 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £50.12 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £58.71 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £76.85 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.34 |
