Customize your workstation, and free up space, with this dual-monitor stand. Mount two monitors on the dual articulating monitor arms, and adjust your displays for optimum viewing with a wide range of motion. The free-standing base gives you flexibility in placing your setup within your workspace.
Work more efficiently with a dual-monitor setup. The horizontal dual-monitor stand lets you mount two VESA mount (75x75, 100x100 mm) monitors, up to 32", with a maximum weight capacity of up to 17.6 lb./8 kg per display.
Mounting your displays on a dual-monitor stand above the desk surface enables you to adjust your display height, position and viewing angles for an ergonomic workspace. The swiveling arms provide maximum viewing flexibility, letting you work in comfort.
It's easy to customize your setup, placing your monitors at the ideal height. Simply adjust the display height along the 16.7" (42.4 cm) pole. You can align your monitors perfectly with the micro-adjustment feature.
Extend the dual articulating arms up to 18.4" (46.8 cm) to position your monitors in the ideal position. Tilt your monitors +90/-40 degrees and swivel +90/-90 degrees for ideal viewing. Rotate your displays for portrait or landscape viewing.
Neatly route your cables, keeping them organized and out of view, with the cable-management channels.
- StarTech.com Dual Monitor Stand, Ergonomic Desktop Monitor Stand for up to 32" VESA Displays, Free-Standing Articulating Universal Computer Monitor Mount, Adjustable Height, Silver - Easy & Quick Assembly stand - for 2 monitors - black, silver
- Product Type
- Stand - desktop
- 92.6 cm x 11.6 cm x 55 cm
- Tilt
- -40° to 90°
- Pan
- -90° to 90°
- Rotation
- -180° to 180°
- Adjustments
- 4.8 kg
- Recommended Use
- 2 monitors
- Recommended Display Size
- 32"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 16 kg
- Material
- Plastic, aluminium, steel
- Black, silver
- 5-year warranty
- 92.6 cm
- 11.6 cm
- 55 cm
- 4.8 kg
- Material
- Black, silver
AV Furniture
- Stand
- Recommended Use
- 2 monitors
- Placing / Mounting
- Desktop
- Cable Management
- Integrated cable management
- 32"
- Tilt
- -40° to 90°
- Pan
- -90° to 90°
- Rotation
- -180° to 180°
- Adjustments
- Max Load Weight
- 16 kg
- Assembly Required
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 55.7 cm x 31.2 cm x 10.5 cm / 5.6 kg
- Limited warranty - 5 years
StarTech.com Desktop Monitor Stand with Cable Hook - Mounting Kit | In Stock | £95.04 |
StarTech.com Dual Monitor Stand | In Stock | £90.65 |
StarTech.com Vertical Dual Monitor Stand | In Stock | £90.36 |
StarTech.com Thin Client Mount - VESA | In Stock | £25.93 |
StarTech.com Under Desk Keyboard Tray | In Stock | £64.60 |
StarTech.com Vertical Dual Monitor Stand | In Stock | £116.66 |
StarTech.com Dual-Monitor Stand - Horizontal - For up to 24" Monitors - S | In Stock | £82.81 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £51.28 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £58.71 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £75.65 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £8.54 |
