StarTech.com Dual Monitor Stand
Quicklinx: C19ZWS00 Mfr#: ARMBARDUO
Accessory Type: Bracket
19 in stock
£82.93 ex VAT
£99.51 inc VAT
Save space by mounting two LCD or LED displays, up to 24" in size, onto a single low-profile base. This dual-monitor stand lets you mount two individual displays, each up to 24" in size, to a single base that you can place in virtually any workspace.
With its dual-crossbar design, this monitor stand lets you mount two monitors in the same physical space as one, so you have more surface area on your desk available for additional hardware or completing physical tasks such as drafting or reading paper documents. The monitor stand features a low-profile flat back that enables you can snugly position your displays against a wall or cubicle, unlike other dual-monitor mounting options.
If you're outfitting an entire office, you can give employees more work space at each desk and use smaller cubicles to maximize your available office real estate.
Adding two monitors to a single computer gives you the additional screen space you need to simplify multitasking and maximize your productivity. Using two displays makes it easier to reference material on one display while working on another, saving you the time and hassle of having to flip back and forth between documents.
The dual-monitor mount features easy-to-adjust height and tilt mechanisms, so you can customize the positioning of your displays to the most comfortable positions without disrupting your work. Plus, the desktop stand enables a hassle-free setup that ensures even installation is comfortable.
StarTech.com Dual Monitor Mount - Supports Monitors 12" to 24" - Adjustable - VESA Monitor Stand for Desk - Low Profile Base - Horizontal - Black (ARMBARDUO) - stand - for LCD display (adjustable arm)
Stand (adjustable arm) - stand mountable
95 cm x 18 cm x 41 cm
Rotation
360°
Adjustments
Height, tilt
6.2 kg
Recommended Use
LCD display
Recommended Display Size
24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Plastic, aluminium, steel
Package Content
Pole, baseplate, 3 x M6x15 screws, cable-management clip (pole), pole cap, height-adjustment ring, crossbar, 2 x VESA monitor mounts, 8 x M4x12 screws, 8 x M4x30 screws, 8 x plastic spacers, allen wrench (3mm), allen wrench (4mm), 2 x cable-management clips (crossbar)
5-year warranty
P/N: ACCSMNT, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, PXT101YUK, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV
95 cm
18 cm
41 cm
6.2 kg
Material
Package Content
AV Furniture
Stand
Design
Adjustable arm
Recommended Use
LCD display
Placing / Mounting
Stand mountable
Cable Management
Integrated cable management
24"
Rotation
360°
Adjustments
Height, tilt
Max Load Weight
8 kg
Adjustable Feet
Assembly Required
Limited warranty - 5 years
C19Z StarTech.com Universal USB 3.0 Laptop Docking Station Dual-Monitor HDMI DVI In Stock £122.07
C19Z StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio In Stock £108.41
C19Z StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video In Stock £139.25
C19Z StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £124.85
C19Z StarTech.com Monitor Mount - USB Passthrough In Stock £154.18
C19Z StarTech.com Dual Monitor Mount - Stackable In Stock £174.45
C19Z StarTech.com Dual Monitor Stand In Stock £82.93
C19Z StarTech.com Under Desk Keyboard Tray In Stock £60.89
C19Z StarTech.com Dual 4K TB3 Dock - M.2 - SD In Stock £331.48
Stock Status: In stock
