Save space and work in comfort by mounting two displays with full-motion positioning. The ARMDUAL30 Dual-Monitor Arm lets you customize your workspace like never before. Increase your comfort and productivity with a dual monitor setup, side-by-side or stacked. The full-motion arms with articulation and spring-assisted height adjustment let you position your monitor and viewing angle anytime, and easily switch from landscape to portrait. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Create a more ergonomic workspace that matches your exact needs, while freeing up valuable space on your desk or table. The interchangeable arms with quick-connect assembly let you design a dual-monitor setup to suit your specific workstation.
In a side-by-side setup, the dual-monitor mount supports two monitors from 12" to 30". It's ideal for numerous uses in the business or home office including graphic design, gaming, photo editing and many others.
In a stacked setup, the dual-monitor mount supports two monitors, from 12" to 24". A vertical setup makes comparison easy in many applications including financial analysis, web design, reviewing spreadsheets and many others. Please note: To support two stacked 24" monitors, the height of each monitor (including the bezel around the display) cannot exceed 14" (35 cm).
The desk-mount monitor arms offer a full range of motion on several axes, letting you tilt, pan and rotate to adjust your viewing angle any time to suit your changing needs. To view longer pages or blocks of code without scrolling, the arms also support landscape-to-portrait display rotation for each monitor.
Raising or lowering your monitors is effortless, with the spring-assisted height adjustment. You can adjust the tension to your own preference.
With its heavy-duty construction, the ARMDUAL30 securely holds two monitors using a standard VESA mount. The dual-monitor mount has a weight capacity of 9 kg (19.8 lb.) per arm.
The snap-and-release design makes the dual-monitor arm mount easy to assemble and customize. For installation flexibility, the included mounting hardware lets you either clamp the monitor mount to the side of your desk or table, or attach it through a grommet hole. The arm mount also features integrated cable management channels that help to keep cables neatly tucked away.
Versatile adjustments
The dual monitor arm features full-motion capabilities, allowing for tilt of 105°, 360° swivel, and pan adjustments to achieve optimal viewing angles. -
Premium materials
Constructed with a combination of plastic, aluminum, and steel, this mounting kit ensures robustness and longevity for everyday use. -
Smart cable management
Integrated cable management system helps maintain a clean workspace by keeping cables organized and out of sight. -
Easy installation
The toolless assembly feature allows for quick and straightforward installation without the need for additional tools. -
Wide compatibility
Designed to accommodate up to 30-inch displays and compatible with VESA mount interfaces of 100 x 100 mm and 75 x 75 mm.
- StarTech.com Desk Mount Dual Monitor Arm - Full Motion Articulating Arms - Premium Dual Monitor Stand - For up to 30" (19.8lb/9kg) VESA Mount Monitors - Tool-less Assembly - Steel & Aluminum mounting kit - full-motion - for LCD display - black, silver
- Product Type
- Mounting kit (full-motion)
- Mounting Components
- Desk mount, grommet clamp
- 61.8 cm x 47.6 cm x 45.1 cm
- Tilt
- 105°
- Rotation
- 360°
- Swivel
- 360°
- Adjustments
- Pan, tilt
- 6.3 kg
- Recommended Use
- LCD display
- Recommended Display Size
- 30"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 9 kg
- Material
- Plastic, aluminium, steel
- Black, silver
- Package Content
- 2 x M6 allen key, 2 x M3 allen key, 2 x spring arm, 2 x swivel arm, 2 x VESA monitor mount, 8 x thumb screws
- 2-year warranty
- Designed For
- P/N: ACCSMNT, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, PXT101YUK, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV
- 61.8 cm
- 47.6 cm
- 45.1 cm
- 6.3 kg
- Material
- Black, silver
- Package Content
AV Furniture
- Mounting kit
- Design
- Full-motion
- Recommended Use
- LCD display
- Cable Management
- Integrated cable management
- 30"
- Tilt
- 105°
- Rotation
- 360°
- Swivel
- 360°
- Adjustments
- Pan, tilt
- Max Load Weight
- 9 kg
- Adjustable Feet
- Limited warranty - 2 years
- Designed For
StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio | In Stock | £57.54 |
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £139.14 |
StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort | In Stock | £85.79 |
StarTech.com Sit-to-Stand Workstation | In Stock | £124.33 |
StarTech.com Monitor Mount - USB Passthrough | In Stock | £165.58 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £217.58 |
StarTech.com Dual Monitor Stand | In Stock | £84.13 |
StarTech.com Desk Mount Quad Monitor Arm | In Stock | £174.76 |
StarTech.com Thin Client Mount - VESA | In Stock | £23.04 |
StarTech.com Under Desk Keyboard Tray | In Stock | £55.82 |
StarTech.com Desk Mount Dual Monitor Arm - Crossbar | In Stock | £101.27 |
StarTech.com Desk Mount Dual Monitor Arm - Dual Swivel Articulating | In Stock | £100.36 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £8.96 |
StarTech.com Triple Monitor Desk Mount | In Stock | £180.85 |
StarTech.com Triple Monitor Desk Mount | In Stock | £173.21 |
StarTech.com Crossbar Dual Monitor Stand | In Stock | £88.42 |
