StarTech.com Sit-to-Stand Workstation
Quicklinx: BWG4WS00 Mfr#: ARMSTS
Accessory Type: Stand
12 In Stock
£121.36 ex VAT
£145.63 inc VAT
Turn your desk into a sit-stand workspace with easy height adjustment, for increased comfort and productivity. This sit-to-stand workstation lets you change your working position throughout the day, to enhance your comfort and productivity.
The sit-to-stand desk workstation is designed to fit you and your needs throughout the day. With one touch, you can switch your position to sitting or standing, to keep a balanced level of movement. The workstation features an advanced pneumatic spring that provides effortless movement - you simply raise or lower the platform with one touch of the lever. You can easily adjust the standing desk to match your exact height requirements, instead of selecting from pre-determined heights. You can also adjust the tension according to the weight of monitors, laptops and other components on the platform, to make raising or lowering the workstation easy.
Create a more ergonomic work environment at a fraction of the cost of a standing desk. This compact sit-to-stand workstation fits easily into your work space. You simply set the workstation on your desk surface, tabletop or another stable work surface (minimum 26" depth).
The sit-stand workstation lets you make the most out of your desk area, and it's easy to integrate it into your current layout. It simply sits on your desktop. The workstation provides lots of space for writing notes or placing accessories on its base and a large keyboard tray that accommodates your keyboard and mouse, making it perfect for any workspace including business settings and home offices.
Setting up your workstation is easy. You can place one monitor (from 12" to 30") directly on the stand. The sit-stand workstation is also compatible with StarTech.com monitor arms.
If you prefer a dual-monitor setup, you can purchase the StarTech.com ARMDUAL Dual Monitor Mount with Articulating Arms, which supports two displays from 12" to 24". You can also create a single-monitor setup with the StarTech.com ARMPIVOT Pivoting Monitor Mount (supports a display from 12" to 30") or the ARMSLIM Monitor Mount with Articulating Arm (supports a display from 12" to 26"). A generous weight capacity of 13 kg (28.7 lb) gives you many options for setup.
  • Flexible use and spacious setup
    The sit-stand workstation lets you make the most out of your desk area, and it's easy to integrate it into your current layout. It simply sits on your desktop. The workstation provides lots of space for writing notes or placing accessories on its base and a large keyboard tray that accommodates your keyboard and mouse, making it perfect for any workspace including business settings and home offices. Setting up your workstation is easy. You can place one monitor (from 12" to 30") directly on the stand. The sit-stand workstation is also compatible with StarTech.com monitor arms. If you prefer a dual-monitor setup, you can purchase the StarTech.com ARMDUAL Dual Monitor Mount with Articulating Arms, which supports two displays from 12" to 24". You can also create a single-monitor setup with the StarTech.com ARMPIVOT Pivoting Monitor Mount (supports a display from 12" to 30") or the ARMSLIM Monitor Mount with Articulating Arm (supports a display from 12" to 26"). A generous weight capacity of 13 kg (28.7 lb) gives you many options for setup. Note: When mounting a StarTech.com monitor arm on ARMSTS you must secure the rear of the workstation to the desk using the C-clamp provided with your monitor arm. The ARMSTS is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Height Adjustable Standing Desk Converter - Sit Stand Desk with One-finger Adjustment - Ergonomic Desk (ARMSTS) mounting kit - for LCD display / keyboard / mouse / notebook - black, silver
Mounting kit - desktop
Mounting Components
Clamp plate, keyboard tray, pneumatic arm, base, keyboard tray backing, workstation, mounting pillar, small pressure pads (keyboard tray), circular pressure pads (base), back plate (keyboard)
68 cm x 85.6 cm x 16 cm
Adjustable Height
16-42.1 cm
Adjustments
12.8 kg
Recommended Use
Recommended Display Size
12"-30"
Max Load Weight
13 kg
Material
Steel
Black, silver
Package Content
2 x M6x8 screws, 4 x M6x25 screws, 16 x M6x12 screws, 1 x M6x95 allen wrench, 1 x M4x55 allen wrench, 1 x M10x50 bolt, 16 x #3/8 - 16 x 50 bolt
P/N: ARMDUAL, ARMPIVOT, ARMPIVOTB, ARMPIVOTE, ARMPIVOTHD, ARMPIVOTV2, ARMPIVSTND, ARMSLIM, ARMUNONB, LTRISERP, MONSTADJD, MONSTADJDL, MONSTADQI
68 cm
85.6 cm
16 cm
Adjustable Height
16-42.1 cm
12.8 kg
Material
Steel
Black, silver
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Placing / Mounting
Desktop
Cable Management
Integrated cable management
12"-30"
Adjustments
Max Load Weight
13 kg
Dimensions & Weight Details
22.8 kg
BWG4 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £135.75
BWG4 StarTech.com Height Adjustable Monitor Arm - Grommet / Desk Mount with Cable Hook In Stock £63.34
BWG4 StarTech.com Articulating Monitor Arm In Stock £118.99
BWG4 StarTech.com Sit-to-Stand Workstation In Stock £121.36
BWG4 StarTech.com Sit Stand Monitor Arm In Stock £182.88
