The Dual-Bay M.2 NVMe SSD Removable Mobile Rack provides an efficient solution for expanding storage capabilities via PCIe x8 slots. With a capacity to accommodate up to two M.2 drives, this interface adapter supports various lengths from 2230 to 2280, ensuring compatibility with a wide range of SSDs. Equipped with a hot-swap feature, the mobile rack allows seamless drive replacements without powering down the system, contributing to improved productivity and convenience. This mobile rack also integrates essential features such as S.M.A.R.T. support, TRIM support, and a key lock for added security. Built from stainless steel, it ensures durability while the LED indicator provides operational status for drives. Additionally, the tool-less installation process simplifies setup, making it an ideal choice for enhancing storage solutions efficiently.
Convenient hot-swap capability
This mobile rack allows users to replace M.2 drives without powering down the system, enhancing operational efficiency. -
Robust build quality
Constructed from stainless steel, this device ensures longevity and protection for internal components against various environmental factors. -
Efficient data transfer rates
With a data transfer rate of 128 Gbit/s, this mobile rack supports high-speed connections and optimal performance for solid-state drives. -
Support for multiple M.2 sizes
Designed to accommodate M.2 drives of sizes 2230, 2242, 2260, and 2280, providing flexibility and compatibility for diverse storage needs. -
User-friendly installation
Features a tool-less installation process, simplifying setup and making it accessible for users of all technical levels.
- StarTech.com Dual-Bay M.2 NVMe SSD Removable Mobile Rack for PCIe x8 Slot - interface adapter - M.2 NVMe Card / PCIe (NVMe) - PCIe 4.0 x8
- Interface adapter - plug-in card
- Bus Type
- PCIe 4.0 x8
- Black
- Expansion Bays
- 2 x hot-swap - M.2 2230/2242/2260/2280
- Hard Drive Form Factor Compatibility
- M.2
- Interface
- Data Transfer Rate
- 128 Gbit/s
- Supported Devices
- Solid state drive
- Max Storage Devices Qty
- 2
- Product Material
- Stainless steel
- 18.6 cm x 12.1 cm x 1.9 cm
- 500 g
- 2-year warranty
- M.2
- Host Bus
- PCIe 4.0 x8
- Product Material
- Stainless steel
- Black
Storage Controller
- Interface
- 128 Gbit/s
- Supported Devices
- Solid state drive
- 2
- Bays
- 2 x M.2 Card - M.2 M key (internal)
- Connections
- X PCIe 4.0 x8
- Included Accessories
- 2 x M.2 mounting screws, keys
- Hot-swappable strorage bay, key lock, tool-less installation, LED indicator, vented, anti-vibration springs, TRIM support, S.M.A.R.T. support, 4Kn drive compatible, bus powered, supports NVM Express
- MTBF
- 40,000 hours
- RoHS
- Limited warranty - 2 years
- 18.6 cm
- 12.1 cm
- 1.9 cm
- 500 g
- Shipping Width
- 23 cm
- Shipping Depth
- 15.1 cm
- Shipping Height
- 4.6 cm
- Shipping Weight
- 500 g
- 0 °C
- 50 °C
- 10 - 60% RH
StarTech.com M.2 NVMe SSD to PCIe x4 Slot | In Stock | £82.68 |
StarTech.com M.2 NVMe Drive Tray | In Stock | £27.38 |
