StarTech.com Dual M.2 NGFF SATA Adapter w/ RAID - 2x M.2 SSDs to 2.5in SATA
Quicklinx: BWG2WS00 Mfr#: 25S22M2NGFFR
£30.11 ex VAT
£36.13 inc VAT
Install two M.2 NGFF SSDs into a 2.5" bay to create high-performance storage with configurable RAID. Boost your system performance by enhancing the capacity, speed and security of your data storage. This two-drive M.2 to SATA adapter lets you install two M.2 solid-state drives in a single 2.5" drive bay and configure a powerful RAID array.
The dual M.2 to SATA adapter supports multiple RAID modes (RAID 0, 1, BIG) helping you to achieve greater SSD capacity or data redundancy, depending on your selected RAID mode. The SSD adapter also supports non-RAID operation (JBOD) when paired with a port-multiplying SATA controller, so both drives can be used independent of one another.
The dual SSD adapter lets you utilize the full potential of your SATA III controller. Using M.2 SSDs in place of a platter drive reduces your data transfer bottlenecks and gives you file transfer speeds of up to 6 Gbps. M.2 SSDs also save you money by reducing your power consumption over regular platter drives.
The M.2 NGFF SATA RAID adapter also provides TRIM support to enhance the stability and performance of your M.2 NGFF SSDs.
The M.2 to SATA adapter features an enclosed housing that helps protect your NGFF (Next Generation Form Factor) SSD. The added protection gives you peace of mind when you are using your M.2 drives in applications that require an added level of durability such as hot-swap drive bays, or external SATA docking stations.
  • Efficient data transfer
    Achieve a data transfer rate of up to 6 Gbps, allowing quick access and management of stored data with minimal delays.
  • Versatile RAID configurations
    Supports multiple RAID levels including RAID 0, RAID 1, JBOD, and BIG, providing flexibility for various storage strategies based on performance or redundancy needs.
  • Compact design
    The adapter's 2.5-inch form factor ensures compatibility and ease of installation within standard drive bays, making it convenient for upgrading existing systems.
  • Environmentally compliant
    Manufactured in accordance with FCC, RoHS, and WEEE standards, ensuring reduced environmental impact and adherence to regulatory requirements.
  • User-friendly indicators
    Equipped with two LED indicators, providing real-time feedback on the status of SSDs connected to the adapter for easier management and troubleshooting.
StarTech.com Dual M.2 SATA Adapter with RAID - 2x M.2 SSDs to 2.5in SATA (6Gbps) RAID Adapter Converter with TRIM Support (25S22M2NGFFR) - storage controller (RAID) - M.2 Card - SATA 6Gb/s
Storage controller (RAID) - internal
Bus Type
SATA 6Gb/s
Black, silver
Compatible Bay
1 2.5"
Hard Drive Form Factor Compatibility
M.2
M.2 Card
Data Transfer Rate
6 GBps
Supported Devices
Disk array (RAID), solid state drive
Channel Qty
2
RAID Level
RAID 0, RAID 1, JBOD, BIG
6.8 cm x 9.8 cm x 0.8 cm
55 g
M.2
Host Bus
SATA 6Gb/s
Black, silver
Storage Controller
M.2 Card
Data Transfer Rate
6 GBps
Supported Devices
Channel Qty
2
RAID Level
ASMedia ASM1092R
2 x M.2 Card - M.2 Card
1 x SATA 6Gb/s - 22 pin Serial ATA
Compatible Bay
1 x internal 2.5"
Screwdriver, screws, mounting hardware
2 LED indicators
FCC, RoHS, WEEE
6.8 cm
9.8 cm
0.8 cm
55 g
50 °C
5 - 95%
BWG2 StarTech.com 24" Serial ATA Cable In Stock £5.16
BWG2 StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
BWG2 StarTech.com 18in SATA Serial ATA Data and Power Combo Cable In Stock £5.76
BWG2 StarTech.com 18in SATA Serial ATA Cable In Stock £2.51
BWG2 StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.06
BWG2 StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.36
BWG2 StarTech.com 12in Latching SATA Cable In Stock £5.48
BWG2 StarTech.com 12in SATA Serial ATA Cable In Stock £4.44
BWG2 StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M In Stock £5.78
BWG2 StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.14
BWG2 StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable In Stock £3.92
BWG2 StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £29.24
BWG2 StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.12
BWG2 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.51
BWG2 StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £14.65
BWG2 StarTech.com Dual M.2 NGFF SATA Adapter w/ RAID - 2x M.2 SSDs to 2.5in SATA In Stock £30.11
BWG2 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.59
BWG2 StarTech.com M.2 SATA Raspberry Pi Adapter In Stock £19.02
BWG2 StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £31.05
BWG2 StarTech.com M.2 to U.2 Adapter In Stock £22.89
BWG2 StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe In Stock £129.01
BWG2 StarTech.com 18in Right Angle SATA Cable In Stock £4.22
