StarTech.com Dual M.2 Enclosure - RAID
Quicklinx: CQSKWS00 Mfr#: SM22BU31C3R
£44.74 ex VAT
£53.68 inc VAT
Turn two M.2 NGFF SATA drives into ultra-fast, portable storage with RAID for increased performance or redundancy. This dual M.2 SATA enclosure with RAID makes it easy to add ultra-fast, portable external storage to your USB-C or USB-A enabled laptop, tablet, smartphone or desktop computer. Its multiple RAID modes provide increased capacity, improved performance, or data redundancy.
Quickly access, transfer, and backup your files wherever you go. This dual-slot M.2 RAID enclosure enables you to easily access your data by creating a high-performance, ultra-portable storage solution using two M.2 (NGFF) SATA SSDs. It's ideal for creative professionals, such as photographers and videographers, as well as professionals in corporate, educational and government sectors who need fast access to important data files, while out in the field or back at the office.
The RAID enclosure enables you to leverage the speed of your M.2 (NGFF) SATA drives by taking advantage of USB 3.1 Gen 2, with data transfer rates of up to 10Gbps. It ensures easy access to your files for data migration and data backups so that you can safeguard important data at all times.
With multiple RAID options, the M.2 RAID enclosure enables you to gain increased storage size, performance, or redundancy. You can enjoy the peace of mind of knowing your files are continually backed up, or take advantage of greater speed and capacity offered by a combined solution. The enclosure supports RAID 0, RAID 1, Spanning, and JBOD, enabling you to choose your preferred backup mode. It also supports SSD TRIM to prolong drive lifespan and performance.
The dual M.2 SATA enclosure provides a highly portable storage solution. With its compact design, you can tuck it away inside your laptop bag or carrying case and take it anywhere - to the office, the lab, or for mobile use, so that you can access your data wherever you go. Engineered with a solid aluminum housing, the dual-slot M.2 SATA enclosure helps to safeguard your data wherever you go.
The M.2 SATA RAID enclosure is powered directly from the USB port on your device, so no external power is required. It comes with two USB cables (USB-C to Micro-B and USB-A to Micro-B) for flexible use with the latest laptops and tablets equipped with a USB-Type C port as well as legacy devices. The enclosure is OS independent, with no additional software or driver installation required, and is compatiIt's also compatible with a Thunderbolt 3 USB-C port.
  • Access your external data at greater speeds
    Quickly access, transfer, and backup your files wherever you go. This dual-slot M.2 RAID enclosure enables you to easily access your data by creating a high-performance, ultra-portable storage solution using two M.2 (NGFF) SATA SSDs. It's ideal for creative professionals, such as photographers and videographers, as well as professionals in corporate, educational and government sectors who need fast access to important data files, while out in the field or back at the office. The RAID enclosure enables you to leverage the speed of your M.2 (NGFF) SATA drives by taking advantage of USB 3.1 Gen 2, with high data transfer rates. It ensures easy access to your files for data migration and data backups so that you can safeguard important data at all times.
  • Increase performance and data redundancy
    The M.2 RAID enclosure enables you to gain increased storage size, performance, or redundancy. You can enjoy the peace of mind of knowing your files are continually backed up, or take advantage of greater speed and capacity offered by a combined solution. The enclosure supports RAID 0, RAID 1, Spanning, and JBOD, enabling you to choose your preferred backup mode. It also supports SSD TRIM to prolong drive lifespan and performance.
  • Make your data more portable
    The dual M.2 SATA enclosure provides a highly portable storage solution. With its compact design, you can tuck it away inside your laptop bag or carrying case and take it anywhere - to the office, the lab, or for mobile use, so that you can access your data wherever you go. Engineered with solid aluminum housing, the dual-slot M.2 SATA enclosure helps to safeguard your data wherever you go. The M.2 SATA RAID enclosure is powered directly from the USB port on your device, so no external power is required. It comes with two USB cables for flexible use with the laptops and tablets equipped with a USB-Type C port as well as legacy devices.
StarTech.com Dual-Slot Hard Drive Enclosure for M.2 SATA SSDs - USB 3.1 (10Gbps) - Aluminum - M.2 to SATA - Raid Drive Enclosure (SM22BU31C3R) - flash storage array
Flash storage array
Max Supported Capacity
2 TB
USB 3.1
0 (installed) / 2 (max)
Storage Controller
RAID (SATA 6Gb/s) - RAID 0, 1, JBOD, BIG
Hard Drive
No HDD
8 cm x 10 cm x 1.5 cm
150 g
P/N: TBLT3MM1MA, TBLT3MM2M, TBLT3MM2MA
Flash storage array
Enclosure Colour
Chassis
0
Supported Devices / Modules Qty
2
Storage
2 TB
HDD Array External Interface
USB 3.1
CPU
ASM1352R
Storage Controller
RAID
Interface Type
SATA 6Gb/s
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD, BIG
Hard Drive
No HDD
Expansion Bays
2 (total) / 2 (free) x internal - M.2 2230/2242/2260/2280
1 x USB 3.1 - 10 pin Micro-USB Type B
USB powered, LED indicator, UASP transfer protocol, supports SPAN mode
1 x SuperSpeed USB 3.1 Type A to micro-USB Type B cable , 1 x SuperSpeed USB-C to micro-USB cable
MTBF
35,000 hours
FCC, RoHS
Screwdriver, screws
8 cm
10 cm
1.5 cm
150 g
CQSK StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP In Stock £24.36
CQSK StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £25.04
CQSK StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £11.02
CQSK StarTech.com USB3.1 Dual External Enclosure In Stock £87.76
CQSK StarTech.com M.2 SATA Enclosure with USB-C In Stock £27.13
CQSK StarTech.com USB 3.1 mSATA Drive Enclosure In Stock £28.75
CQSK StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C In Stock £59.20
CQSK StarTech.com M.2 NVMe PCIe SSD Enclosure - IP67 water/dust resistance In Stock £70.36
