StarTech.com 4x M.2 PCIe to TB3 Enclosure
Quicklinx: GVKXWS00 Mfr#: M2E4BTB3
Type: Storage enclosure
HD Size: M.2
Power Supply: Power adapter
Hurry, only 1 left in stock!
£341.51 ex VAT
£409.81 inc VAT
This Thunderbolt 3 to 4x M.2 PCIe SSD enclosure enables you to turn four M-Key PCI-Express based M.2 NVMe or AHCI solid state drives (SSDs) into a high-performance external storage solution. The SSD enclosure is self-powered with an included 72W EPS power supply that powers the enclosure, the connected drives, and provides up to 15W of power to any downstream Thunderbolt 3 devices. A 2.3 ft. (70 cm) Thunderbolt 3 Certified host cable is also included, to connect the enclosure to your computer.
  • High Performance M.2 Storage via 40Gbps Thunderbolt 3
    The enclosure is compatible with 80mm M.2 PCIe based (M-Key) single/double-sided SSDs. Create an external storage solution that utilizes the high-performance bandwidth available to your Thunderbolt 3 port, providing combined data transfer speeds of up to 40Gbps for up to four drives. The vented metal enclosure features thermal pads and a cooling fan to ensure your SSDs are operating at optimal temperatures.
  • Dedicated 8Gbps Throughput for Each Individual Drive
    A single 8 Gbps PCIe lane is dedicated to each connected drive. This ensures consistent read/write performance across the entire enclosure, regardless of individual drive activity. The enclosure also supports software RAID with storage management systems like Storage Spaces (Microsoft), RAID Assistant (macOS), or mdraid/mdadm (Linux). The support for software RAID, combined with exceptional drive performance, makes this the ideal enclosure for creative professionals working with large files such as high-resolution graphics, video, and CAD files.
  • Thunderbolt Certified
    This enclosure is Thunderbolt Certified to ensure an optimal user experience and compatibility when connected to a Thunderbolt 3 host device, such as a MacBook Pro 16, 13, Air, Lenovo ThinkPad X1 Carbon / T Series, Dell XPS / Latitude / Precision or HP EliteBook. The external drive enclosure is also forward compatible with Thunderbolt 4 devices (at Thunderbolt 3 performance).
  • Additional Ports for Workspace Flexibility
    The enclosure features a DisplayPort output port, enabling you to connect a DisplayPort monitor to your computer through the Thunderbolt 3 enclosure, with resolutions up to 4K 60Hz. The enclosure also features a downstream Thunderbolt 3 port for daisy chaining an additional TB3 device or connect an additional TB3 compatible display (up to 5K 60Hz). M2E4BTB3 is backed by a 2-year StarTech.com warranty, with free lifetime North American based multilingual technical support. Notes: • This device is not compatible with SATA based (B-Keyed or M+B Keyed) M.2 solid state drives. • This device does not support Thunderbolt 2 or Thunderbolt 1 host devices using interface adapters. • This device only supports 80mm M.2 SSDs. • Connected downstream devices share bandwidth with connected SSDs and may reduce overall data transfer performance when connected. • Apple Mac computers with M1 processors can only support one external display connected through the SSD enclosure. However, Apple Mac computers with Intel or M1 Max / Pro processors can support dual external displays connected through the SSD enclosure.
StarTech.com 4 Bay Thunderbolt 3 NVMe Enclosure, For M.2 NVMe Solid State Drives, 1x DisplayPort Video & 2x TB3 Downstream Ports, Up to 40Gbps, 72W Power Supply - 4 Bay M.2 SSD External Hard Drive Enclosure (M2E4BTB3) - storage enclosure - M.2 NVMe Card / PCIe (NVMe) - Thunderbolt 3
Storage enclosure - external
Bus Type
Thunderbolt 3
North Africa, Japan, United Kingdom, Europe, Australia, New Zealand
Expansion Bays
4 x internal - M.2 NGFF 2280
Hard Drive Form Factor Compatibility
M.2
Data Transfer Rate
40 GBps
Supported Devices
Solid state drive
Max Storage Devices Qty
4
Power Source
USB bus
AC 110-120 V
16 cm x 12 cm x 2 cm
610 g
M.2
Host Bus
Thunderbolt 3
Storage Controller
Data Transfer Rate
40 GBps
Supported Devices
Solid state drive
4
Bays
1 x DisplayPort - DisplayPort (external) , 4 x PCIe 3.0 x1 (NVMe) - M.2 M key (internal)
1 x Thunderbolt 3 - 24 pin USB-C
1 x Thunderbolt 3 cable - external - 70 cm
Supports AHCI mode, LED indicator, TRIM support, 4Kn drive compatible, S.M.A.R.T. support
MTBF
50,000 hours
Power Source
USB bus
Power adapter
AC 110-120 V
16 cm
12 cm
2 cm
610 g
Shipping Width
23.4 cm
Shipping Depth
15.7 cm
Shipping Height
13.2 cm
Shipping Weight
620 g
5 °C
45 °C
20 - 80%
GVKX StarTech.com 0.5m Thunderbolt 3 Cable In Stock £19.71
GVKX StarTech.com 2m Thunderbolt 3 Cable White In Stock £38.63
GVKX StarTech.com 0.8m / 2.7ft Thunderbolt 3 to Thunderbolt 3 Cable - 40Gbps In Stock £31.96
GVKX StarTech.com 3ft DisplayPort 1.4 8K 60Hz In Stock £16.22
HD Size: M.2
