Mount two 2.5in SATA SSDs/HDDs into a single 3.5in drive bay. The BRACKET25X2 Dual hard drive mounting bracket kit enables you to maximize the internal mounting space of your computer, by installing two 2.5in SATA hard drives (HDD) or solid state drives (SSD) into a single 3.5in mounting bay. The bracket can be used with IDE drives using the 2.5in to 3.5in IDE Hard Drive cable adapter (IDE4044).
For a hassle-free installation, the hard drive mounting kit includes all required data and power cabling for both SATA drives.
The BRACKET25X2 features solid steel construction.
Compact design
This mounting bracket kit allows the installation of two 2.5" drives into a single 3.5" bay, saving space and maximizing storage efficiency. -
Efficient cable management
Includes Serial ATA cables and a power Y cable, ensuring a tidy setup while providing all necessary connections for immediate use.
 - StarTech.com 2.5" to 3.5" SATA Hard Drive Mounting Bracket Kit - Dual SATA SSDs/HDDs Mounting Bracket for Mounting Bay (BRACKET25X2) - storage bay adapter
 - Storage bay adapter
 - Steel
- Supported Form Factor
 - 3.5" to 2.5"
- Expansion Bays
 - 2 x internal - 2.5"
- Compatible Bay
 - 1 3.5"
 - 10.2 cm x 11.6 cm x 2.2 cm
 - 150 g
 - Limited lifetime warranty
- Designed For
 - P/N: 25S22M2NGFFR, 25SAT22MSAT, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, ST521PMINT
 - 3.5" to 2.5"
 - Steel
Storage Controller
- Processor
 - No CPU
- Bays
- Compatible Bay
 - 1 x internal 3.5"
- Cables Included
 - 1 x Serial ATA power Y cable , 1 x Serial ATA cable
 - RoHS
 - Limited warranty - lifetime
 - 10.2 cm
 - 11.6 cm
 - 2.2 cm
 - 150 g
- Designed For
                        StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.42 |
                        StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay | In Stock | £2.95 |
                        StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.06 |
                        StarTech.com 12in Latching SATA Cable | In Stock | £5.50 |
                        StarTech.com 24in Latching SATA Cable | In Stock | £6.76 |
                        StarTech.com 4x SATA Power Splitter Adapter Cable | In Stock | £6.36 |
                        StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.12 |
                        StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £19.99 |
                        StarTech.com 2.5" SSD/HDD Mounting Bracket | In Stock | £4.21 |
                        StarTech.com 2.5 to 3.5 Hard Drive Adapter | In Stock | £22.96 |
                        StarTech.com 5 Pack - 2.5" SSD / HDD Mounting Bracket for 3.5" Drive Bay | In Stock | £16.09 |
                        StarTech.com 18in Right Angle SATA Cable | In Stock | £4.22 |
