StarTech.com DP to HDMI Adapter with HDR
Quicklinx: F2K7WS00 Mfr#: DP2HD4K60H
More than 50 In Stock
£25.56 ex VAT
£30.67 inc VAT
This DisplayPort to HDMI Adapter lets you connect your DP equipped computer to an HDMI display. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
With brighter colors and greater contrast, the adapter is ideal for: Creating eye-catching visuals for photography, videography, cinematography; Displaying crisp digital signage walls; Delivering enriched presentations.
The DisplayPort to HDMI adapter is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840 x 2160) and bandwidths up to 18Gbps. The adapter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI and DisplayPort at their supported maximum resolutions.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
This lightweight video adapter is highly portable, with a small footprint design. It's the perfect accessory for your DP supported devices, fitting easily into your carrying case.
To ensure easy operation and installation, this unique DP to HDMI adapter allows for plug-and-play installation without any additional software or drivers.
To achieve HDR, your USB-C port must support DisplayPort 1.4 and your display must support HDMI 2.0b. NVIDIA graphics adapters may not support 4:4:4 chroma subsampling and 5.1/7.1 audio output, when used with this adapter.
  • True 4K at 60Hz and HDR
    The DisplayPort to HDMI adapter is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840 x 2160) and bandwidths up to 18Gbps. The adapter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI and DisplayPort at their supported maximum resolutions. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
  • Ideal for Travel
  • Hassle-Free Setup
    To ensure easy operation and installation, this unique DP to HDMI adapter allows for plug-and-play installation without any additional software or drivers. DP2HD4K60H is backed by a 3-year StarTech.com warranty and free lifetime technical support. Notes:
StarTech.com DisplayPort to HDMI Adapter, 4K 60Hz HDR10 Active DisplayPort 1.4 to HDMI 2.0b Video Converter, 4K DP to HDMI Adapter Dongle for Monitor/Display/TV, Latching DP Connector - Ultra HD, EMI Shielding (DP2HD4K60H) - adapter - DisplayPort / HDMI - 25.16 cm
Cable
Adapter - DisplayPort / HDMI
Shielded
Length
25.16 cm
Connector
DisplayPort - male - latched (input)
Connector (Second End)
HDMI - female (output)
4K support
3-year warranty
P/N: ST121HD20FXA, SV231DHU34K6, SV231HU34K6, SV431HU34K6
Cable Type
Adapter 4K support
Interface Supported
DisplayPort / HDMI
Shielded
Length
25.16 cm
HDR support, DPCP compliant, 60+ Hz refresh rate
Connector
20 pin DisplayPort - male - latched (input)
19 pin HDMI Type A - female (output)
FCC, RoHS, HDCP 2.2
5.6 cm
1.14 cm
30 g
Limited warranty - 3 years
F2K7 StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter In Stock £18.78
F2K7 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £10.94
F2K7 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.45
F2K7 StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £20.38
F2K7 StarTech.com Mini DisplayPort to HDMI - 4K In Stock £24.91
F2K7 StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £23.58
F2K7 StarTech.com 5m 15ft Premium 4K HDMI Cable In Stock £25.63
F2K7 StarTech.com 7m 23ft Premium 4K HDMI Cable In Stock £38.28
F2K7 StarTech.com 0.5m Premium 4K HDMI Cable In Stock £10.05
F2K7 StarTech.com DP to HDMI Adapter Cable, 4K 1m In Stock £22.05
F2K7 StarTech.com DP to HDMI Adapter Cable, 4K 2m In Stock £24.24
