Create feature-rich HDMI connections that are certified to be error-free. This 0.5-meter High Speed HDMI cable has been tested in accordance with the Premium HDMI Cable Certification Program. This ensures it's able to deliver the newest technical features that the latest HDMI specifications have to offer, including enhanced resolutions and protection against EMI interference.
Each of the certified Premium High Speed HDMI Cables is labeled with unique anti-counterfeiting authentication, so you can be confident that you have received a genuine certified cable.
The cable supports resolutions of up to 4K@60Hz (3840x2160p) and bandwidths of up to 18Gbps. It also supports HDR (High Dynamic Range) for higher contrast ratio and vivid colors.
With higher resolutions, increased speeds, and sharper images, you can expect an enhanced video experience. The cable is guaranteed to provide the very best HDMI capabilities available today. It's the perfect cable for creating dependable home theater connections or providing lifelike digital signage.
Plus, the cable also supports up to 32 uncompressed digital audio channels to provide crystal-clear sound. The cable is also backward compatible with previous HDMI specifications and will work with all of your existing HDMI devices.
The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center. This gives you the assurance that the cable will deliver the high-bandwidth enabled features you need. An EMI test is also performed to ensure the cable minimizes interference with wireless signals.
The cable delivers dual video streams so that you can view two videos simultaneously on the same display. Your display must support Multi-View in order to take advantage of dual video streams.
                Experience the latest that HDMI has to offerThe cable supports resolutions of up to 4K@60Hz (3840x2160p) and bandwidths of up to 18Gbps. It also supports HDR (High Dynamic Range) for higher contrast ratio and vivid colors. With higher resolutions, increased speeds, and sharper images, you can expect an enhanced video experience. The cable is guaranteed to provide the very best HDMI capabilities available today. It's the perfect cable for creating dependable home theater connections or providing lifelike digital signage. Plus, the cable also supports up to 32 uncompressed digital audio channels to provide crystal-clear sound. The cable is also backward compatible with previous HDMI specifications and will work with all of your existing HDMI devices.
                Provide superior connections with Premium HDMI certificationThe cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center. This gives you the assurance that the cable will deliver the high-bandwidth enabled features you need. An EMI test is also performed to ensure the cable minimizes interference with wireless signals.
                Watch dual video streams on a single displayThe cable delivers dual video streams so that you can view two videos simultaneously on the same display. Your display must support Multi-View in order to take advantage of dual video streams. The HDMM50CMP is backed by StarTech.com's Lifetime Warranty.
- StarTech.com StarTech.com Premium Certified High Speed HDMI 2.0 Cable with Ethernet - 1.5ft 0.5m - HDR 4K 60Hz - 20 inch Short HDMI Male to Male Cord (HDMM50CMP) - HDMI cable with Ethernet - 50 cm
- Cable
- American Wire Gauge (AWG)
- 34
- Length
- 50 cm
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- HDMI CEC support (Consumer Electronics Control), 4K format support, HDR support
- 2-year warranty
- Designed For
- P/N: CDP2HD4K60H, CDPHDMDP2HD, DP2HD4K60H, KITBXDOCKPEU, KITBXDOCKPNA, KITBXDOCKPUK, KITBZDOCK, MOD4DOCKACPD, ST122HD202, ST124HD202, TB3DKM2HDL, USBC-HDMI-CDP2HD4K60
- Cable Type
- 34
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 50 cm
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS, WEEE, ITU-R BT.2020
- 100 g
- Limited warranty - 2 years
- Designed For
|  | StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
|  | StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.85 |
|  | StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £19.66 |
|  | StarTech.com 5m 15ft Premium 4K HDMI Cable | In Stock | £24.09 |
|  | StarTech.com 7m 23ft Premium 4K HDMI Cable | In Stock | £35.52 |
|  | StarTech.com 0.5m Premium 4K HDMI Cable | In Stock | £9.55 |
