This DisplayPort to HDMI Adapter lets you connect your DP equipped computer to an HDMI display. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
With brighter colors and greater contrast, the adapter is ideal for: Creating eye-catching visuals for photography, videography, cinematography; Displaying crisp digital signage walls; Delivering enriched presentations.
The DisplayPort to HDMI adapter is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840 x 2160) and bandwidths up to 18Gbps. The adapter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI and DisplayPort at their supported maximum resolutions.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
This lightweight video adapter is highly portable, with a small footprint design. It's the perfect accessory for your DP supported devices, fitting easily into your carrying case.
To ensure easy operation and installation, this unique DP to HDMI adapter allows for plug-and-play installation without any additional software or drivers.
To achieve HDR, your USB-C port must support DisplayPort 1.4 and your display must support HDMI 2.0b. NVIDIA graphics adapters may not support 4:4:4 chroma subsampling and 5.1/7.1 audio output, when used with this adapter.
True 4K at 60Hz and HDR
The DisplayPort to HDMI adapter is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840 x 2160) and bandwidths up to 18Gbps. The adapter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI and DisplayPort at their supported maximum resolutions. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging. -
Ideal for Travel
This lightweight video adapter is highly portable, with a small footprint design. It's the perfect accessory for your DP supported devices, fitting easily into your carrying case. -
Hassle-Free Setup
To ensure easy operation and installation, this unique DP to HDMI adapter allows for plug-and-play installation without any additional software or drivers. DP2HD4K60H is backed by a 3-year StarTech.com warranty and free lifetime technical support. Notes:
- StarTech.com DisplayPort to HDMI Adapter, 4K 60Hz HDR10 Active DisplayPort 1.4 to HDMI 2.0b Video Converter, 4K DP to HDMI Adapter Dongle for Monitor/Display/TV, Latching DP Connector - Ultra HD, EMI Shielding (DP2HD4K60H) - adapter - DisplayPort / HDMI - 25.16 cm
- Cable
- Adapter - DisplayPort / HDMI
- Technology
- Shielded
- Length
- 25.16 cm
- Black
- Connector
- DisplayPort - male - latched (input)
- Connector (Second End)
- HDMI - female (output)
- 4K support
- 3-year warranty
- Designed For
- P/N: ST121HD20FXA, SV231DHU34K6, SV231HU34K6, SV431HU34K6
- Cable Type
- Adapter 4K support
- Interface Supported
- Technology
- Shielded
- Length
- 25.16 cm
- HDR support, DPCP compliant, 60+ Hz refresh rate
- Black
- Connector
- 20 pin DisplayPort - male - latched (input)
- 19 pin HDMI Type A - female (output)
- FCC, RoHS, HDCP 2.2
- 5.6 cm
- 1.14 cm
- 30 g
- Limited warranty - 3 years
- Designed For
StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter | In Stock | £18.77 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £12.23 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.75 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £20.15 |
StarTech.com Mini DisplayPort to HDMI - 4K | In Stock | £21.56 |
StarTech.com DisplayPort to HDMI - 4K 60Hz | In Stock | £22.55 |
StarTech.com 5m 15ft Premium 4K HDMI Cable | In Stock | £24.31 |
StarTech.com 7m 23ft Premium 4K HDMI Cable | In Stock | £35.86 |
StarTech.com 0.5m Premium 4K HDMI Cable | In Stock | £10.74 |
StarTech.com DP to HDMI Adapter Cable, 4K 3m | In Stock | £21.89 |
StarTech.com DP to HDMI Adapter Cable, 4K 1m | In Stock | £19.07 |
StarTech.com DP to HDMI Adapter Cable, 4K 2m | In Stock | £20.71 |
