StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla
Quicklinx: FLYVWS00 Mfr#: SSPMSUDWM
Device Type: Docking Station
Type: Docking Station Mount
Device Screen Size: [N/A]
Colour: Black
Hurry, only 1 left in stock!
£9.26 ex VAT
£11.11 inc VAT
Create a clutter-free workspace by mounting your docking station or hub, freeing up space on your desktop. This docking station mount makes it easy to mount a compatible StarTech.com dock or hub to the wall, under your desk or counter, or to another solid surface.
Made in Canada, the sturdy and durable dock and hub mount is engineered from 10 gauge steel (3.3 mm thick).
Wall mount your laptop docking station or hub to free up space in business offices, commercial spaces, warehouses and industrial environments. You can also mount it under your desk to tuck it away, while still allowing easy access. It's also ideal for space-constrained areas, including hot desks and shared workstations, mobile and wall-mounted workstations, and home offices.
This innovative mount is designed to work exclusively with compatible StarTech.com products including: Dual 4K Universal Docking Station - USB-C / USB 3.0 - 100W PD (DK30C2DPEP); Dual 4K Universal Docking Station - USB-C / USB 3.0 - 100W PD (DK30C2DPEPUE); Dual 4K Universal Docking Station - USB-C / USB 3.0 - 60W PD (DK30C2DPPD); Dual 4K Universal Docking Station - USB-C / USB 3.0 - 60W PD (DK30C2DPPDUE); Thunderbolt 3 Dock with USB-C Laptop Compatibility (TB3CDK2DP); Thunderbolt 3 Dock with USB-C Laptop Compatibility (TB3CDK2DPUE); 4-Port USB-C 10Gbps Hub - USB 3.1 to 3x USB-A + 1x USB-C (HB31C3A1CS); 4-Port USB-C 10Gbps Hub - USB 3.1 to 4x USB-A - Self Powered (HB31C4AS); 3-Port USB-C Hub with GbE - USB 3.1 (10Gbps) (HB31C2A1CGS) .
The docking station mounting kit, complete with mounting plate and screws, makes it easy to mount your compatible dock or hub to a flat surface.
StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Plate - mounting plate
Mounting plate
Placing / Mounting
Wall mountable, under-desk mountable
Package Content
4 M3x5mm countersunk screws, 4 #5-20 x 5/8" wood screws
Product Material
10 gauge steel
6 cm x 12 cm x 0.33 cm
180 g
5-year warranty
P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, HB31C2A1CGS, HB31C3A1CS, HB31C4AS, TB3CDK2DP, TB3CDK2DPUE, TB3CDOCKDP
Mounting plate
Placing / Mounting
Product Material
10 gauge steel
Package Content
6 cm
12 cm
0.33 cm
180 g
12.5 cm x 22.5 cm x 1 cm / 186 g
RoHS, REACH
TAA Compliant
Limited warranty: - 5 years
FLYV StarTech.com Adjustable CPU Wall Mount In Stock £32.51
FLYV StarTech.com Thin Client Mount - VESA In Stock £22.48
FLYV StarTech.com 4-Port USB C Hub USB 3.1 Gen 2 (10Gbps) 3x USB-A & 1x USB-C In Stock £58.09
FLYV StarTech.com TV Accessory Mount - Universal - Media Player/Apple TV In Stock £26.75
FLYV StarTech.com PC Wall Mount Bracket/Holder In Stock £57.85
FLYV StarTech.com Computer Tower Cart, Rolling In Stock £31.35
FLYV StarTech.com VESA Mounting Bracket In Stock £7.64
Colour: Black
