StarTech.com Computer Tower Cart, Rolling
Quicklinx: HVM9WS00 Mfr#: CPUMOBILESTND
Hurry, only 2 left in stock!
£31.35 ex VAT
£37.62 inc VAT
  • Robust construction
    Crafted from steel, this computer tower cart offers a sturdy foundation for your personal computer, ensuring it remains secure whether in motion or stationary.
  • Versatile mobility
    Equipped with four wheels, this rolling CPU caddy provides effortless mobility, allowing you to easily move your computer to the desired location without the need for heavy lifting.
  • Adjustable design
    The adjustable frame accommodates various computer tower sizes, ensuring a snug fit for enhanced stability. This flexibility makes it an ideal choice for a wide range of personal computers.
  • Enhanced stability
    Included anti-slip pads for both the side walls and base prevent movement and slipping, ensuring your computer stays securely in place even on smooth surfaces.
StarTech.com Computer Tower Cart Rolling CPU Caddy w/ Wheels, Adjustable cart - for personal computer - black
Cart
25.7 cm x 27 cm
Adjustable Width
13.2-22 cm
3.4 kg
Recommended Use
Personal computer
Max Load Weight
21 kg
Material
Steel
Wheels Qty
4
Package Content
4 x washers, wrench, base, 4 x casters, 2 x side walls, 2 x side walls anti-slip pads, base anti-slip pad, 4 x assembly screws, 4 x wing nuts
5-year warranty
25.7 cm
27 cm
Adjustable Width
13.2-22 cm
3.4 kg
Material
Steel
Package Content
AV Furniture
Cart
Recommended Use
Personal computer
Max Load Weight
21 kg
Wheels Qty
4
Limited warranty - 5 years
HVM9 StarTech.com Rolling TV Cart/Portable Mount In Stock £418.75
