StarTech.com DisplayPort USB KVM Switch
Quicklinx: 76QJWS00 Mfr#: SV231DPDDUA
Type: KVM / audio switch
Connectivity: KVM
Ports: 2
More than 50 in stock
£198.60 ex VAT
£238.32 inc VAT
Control 2 high-resolution dual DisplayPort computers with a single console. The SV231DPDDUA 2-Port USB Dual DisplayPort KVM Switch with Audio and USB 2.0 Hub combines next generation digital display standards with seamless KVM control, allowing you to switch between 2 dual head or twin DisplayPort systems. Also ideal for systems with a single DisplayPort output, and a second video source such as DVI or HDMI, using a low cost accessory adapter.
Delivering multi-computer control for high-res multimedia applications, the dual view KVM supports resolutions of 2560x1600 (@60 Hz) with DisplayPort HD audio, as well as 2-channel analog stereo audio and microphone input.
Suitable for high quality static imaging, such as medical applications (MRI, X-ray, etc.), a maximum resolution of 3840x2400 is supported at reduced refresh rates.
StarTech.com Dual Monitor DisplayPort KVM Switch - 2 Port - USB 2.0 Hub - Audio and Microphone - DP KVM Switch (SV231DPDDUA) - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub
16.1 cm x 10 cm x 5.8 cm
1.2 kg
3-year warranty
P/N: IM12D1500P, SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2560 x 1600
4 x DisplayPort , 2 x microphone input mini-jack , 2 x audio output mini-jack , 2 x USB Type B , 2 x USB Type A , 2 x DisplayPort , 1 x microphone input mini-jack , 1 x audio output mini-jack , 2 x USB Type A
External power adapter
FCC, RoHS
16.1 cm
10 cm
5.8 cm
1.2 kg
Limited warranty - 3 years
0 - 80%
76QJ StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.33
76QJ StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.81
76QJ StarTech.com 25 ft DisplayPort Cable with Latches - M/M In Stock £45.83
76QJ StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £192.66
76QJ StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £149.58
76QJ StarTech.com DisplayPort USB KVM Switch In Stock £198.60
76QJ StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.15
76QJ StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.69
76QJ StarTech.com 2 Port USB DisplayPort Cable KVM Switch w/ Audio and Remote Switch - USB Powered In Stock £60.88
76QJ StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable In Stock £301.19
76QJ StarTech.com 2 Port Dual DP KVM Switch - 4K In Stock £256.91
Connectivity: KVM
Ports: 2
Price Range Ex VAT: 150 - 300
