StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz
Quicklinx: DDG9WS00 Mfr#: SV431DPUA2
Type: KVM
Ports: 4
£336.44 ex VAT
£403.72 inc VAT
This 4-port DP KVM switch combines a 4K 60Hz display with KVM switch control of four connected PC and MAC computers. A simple yet comprehensive solution, this 4-port DisplayPort KVM switch combines 4K (60Hz) digital display capability with seamless KVM control of up to 4 connected PC computers and with Mini-DisplayPort adapters, it is also compatible with MAC computers and laptops, convertible notebooks, and tablets.
The DisplayPort KVM switch supports resolutions up to 4K at 60Hz and can drive one large DP display with ease for maximum viewing space.
Featuring audio and USB peripheral support along with both front-panel push-button and hotkey switching, and offering a small form factor with rear connection ports, this 4-port KVM switch will help to minimize workspace disruptions.
The integrated USB 2.0 hub lets you share two additional peripherals among attached computers as if they were directly connected. Sharing USB peripherals using the integrated hub eliminates the expense of duplicate devices such as printers, scanners, and so on.
If you'd like to mount this KVM switch to your server rack, StarTech.com offers a 1U Rackmount Bracket (sold separately) that turns this KVM into a rack-mountable KVM.
StarTech.com 4 Port DisplayPort KVM Switch, 4K 60Hz, Single Display, Dual Port UHD DP 1.2 USB KVM Switch with Integrated USB 2.0 Hub and Audio, Dell, HP, Apple, Lenovo, TAA Compliant - Keyboard/Video/Mouse Switch (SV431DPUA2) - KVM / audio switch - 4 ports
Enclosure Type
1U
Subtype
KVM
Ports
4 x KVM / audio
KVM Users Qty
1 local user
4K resolution support
AC 100 - 240 V 0.6 A
13.1 cm x 22 cm x 4.5 cm
160 g
Australia, Japan, New Zealand, North America, United Kingdom, Europe
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
4 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3684 x 2160 @ 60 Hz
Status Indicators
Port status, power
4 x DisplayPort , 4 x USB 2.0 Type B , 8 x audio output mini-jack , 1 x DisplayPort , 2 x audio output mini-jack , 4 x USB Type A
External power adapter
AC 100 - 240 V
Electric Current Required
0.6 A
18 Watt
4 foot pads
FCC, RoHS, WEEE
13.1 cm
22 cm
4.5 cm
160 g
Shipping Weight
190 g
0 - 40%
Min Storage Temperature
-10 °C
Max Storage Temperature
60 °C
DDG9 StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.24
DDG9 StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £197.31
DDG9 StarTech.com DisplayPort USB KVM Switch In Stock £230.07
DDG9 StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £22.32
DDG9 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
DDG9 StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.37
DDG9 StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.56
DDG9 StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £2.97
DDG9 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
DDG9 StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.73
DDG9 StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable In Stock £351.01
DDG9 StarTech.com 2 Port Dual DP KVM Switch - 4K In Stock £251.98
DDG9 StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
DDG9 StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
DDG9 StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz In Stock £336.44
DDG9 StarTech.com 4PT Dual DP KVM Switch 4K60 In Stock £583.16
DDG9 StarTech.com 2 Pt DisplayPort KVM In Stock £294.39
DDG9 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.72
DDG9 StarTech.com 2 Port USB C KVM Switch In Stock £77.13
DDG9 StarTech.com 2 Port Hybrid USB-C KVM Switch In Stock £32.88
DDG9 StarTech.com 4-Port KM Switch, USB Switch In Stock £231.19
Type: KVM
Ports: 4
