StarTech.com DisplayPort USB KVM Switch
Quicklinx: 76QJWS00 Mfr#: SV231DPDDUA
Type: KVM / audio switch
Connectivity: KVM
Ports: 2
Hurry, only 3 left in stock!
£288.72 ex VAT
£346.46 inc VAT
Control 2 high-resolution dual DisplayPort computers with a single console. The SV231DPDDUA 2-Port USB Dual DisplayPort KVM Switch with Audio and USB 2.0 Hub combines next generation digital display standards with seamless KVM control, allowing you to switch between 2 dual head or twin DisplayPort systems. Also ideal for systems with a single DisplayPort output, and a second video source such as DVI or HDMI, using a low cost accessory adapter.
Delivering multi-computer control for high-res multimedia applications, the dual view KVM supports resolutions of 2560x1600 (@60 Hz) with DisplayPort HD audio, as well as 2-channel analog stereo audio and microphone input.
Suitable for high quality static imaging, such as medical applications (MRI, X-ray, etc.), a maximum resolution of 3840x2400 is supported at reduced refresh rates.
StarTech.com Dual Monitor DisplayPort KVM Switch - 2 Port - USB 2.0 Hub - Audio and Microphone - DP KVM Switch (SV231DPDDUA) - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub
16.1 cm x 10 cm x 5.8 cm
1.2 kg
3-year warranty
P/N: IM12D1500P, SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2560 x 1600
4 x DisplayPort , 2 x microphone input mini-jack , 2 x audio output mini-jack , 2 x USB Type B , 2 x USB Type A , 2 x DisplayPort , 1 x microphone input mini-jack , 1 x audio output mini-jack , 2 x USB Type A
External power adapter
FCC, RoHS
16.1 cm
10 cm
5.8 cm
1.2 kg
Limited warranty - 3 years
0 - 80%
76QJ StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £277.08
76QJ StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.00
76QJ StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £192.19
76QJ StarTech.com DisplayPort USB KVM Switch In Stock £288.72
76QJ StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
76QJ StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.94
76QJ StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.82
76QJ StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.59
76QJ StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.74
76QJ StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.39
76QJ StarTech.com 2-port Dual VGA KVM Switch In Stock £162.42
76QJ StarTech.com 4-port Dual VGA KVM Switch In Stock £176.91
76QJ StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable In Stock £395.01
76QJ StarTech.com 2 Port Dual DP KVM Switch - 4K In Stock £268.79
76QJ StarTech.com DC Power Adapter - 12V, 2A In Stock £12.66
76QJ StarTech.com DC Power Adapter - 12V, 5A In Stock £41.16
76QJ StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz In Stock £378.71
76QJ StarTech.com 4PT Dual DP KVM Switch 4K60 In Stock £656.24
76QJ StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display In Stock £554.15
76QJ StarTech.com 2 Pt DisplayPort KVM In Stock £331.28
76QJ StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz In Stock £85.19
76QJ StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable In Stock £102.14
76QJ StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.26
Connectivity: KVM
Ports: 2
