StarTech.com DisplayPort USB KVM Switch
Quicklinx: 76QJWS00 Mfr#: SV231DPDDUA
Type: KVM / audio switch
Connectivity: KVM
Ports: 2
Hurry, only 2 left in stock!
£287.60 ex VAT
£345.12 inc VAT
Control 2 high-resolution dual DisplayPort computers with a single console. The SV231DPDDUA 2-Port USB Dual DisplayPort KVM Switch with Audio and USB 2.0 Hub combines next generation digital display standards with seamless KVM control, allowing you to switch between 2 dual head or twin DisplayPort systems. Also ideal for systems with a single DisplayPort output, and a second video source such as DVI or HDMI, using a low cost accessory adapter.
Delivering multi-computer control for high-res multimedia applications, the dual view KVM supports resolutions of 2560x1600 (@60 Hz) with DisplayPort HD audio, as well as 2-channel analog stereo audio and microphone input.
Suitable for high quality static imaging, such as medical applications (MRI, X-ray, etc.), a maximum resolution of 3840x2400 is supported at reduced refresh rates.
  • Versatile video resolution
    The KVM switch supports up to 2560 x 1600 resolution, providing clarity across dual monitors for a visual experience.
  • Convenient USB hub integration
    Featuring a built-in 2-port USB 2.0 hub, this KVM switch facilitates easy connection to additional peripherals such as printers and external storage devices.
  • Robust operational parameters
    The KVM switch functions in varied environmental conditions, with a minimum operating temperature of 0°C and a maximum of 40°C, along with a humidity range of 0 - 80%.
  • User-friendly design
    Engineered for one local user controlling two computers, this KVM switch simplifies multitasking and enhances work efficiency.
  • Reliable compliance standards
    This device complies with important standards like FCC and RoHS, ensuring it meets necessary environmental and safety regulations.
StarTech.com Dual Monitor DisplayPort KVM Switch - 2 Port - USB 2.0 Hub - Audio and Microphone - DP KVM Switch (SV231DPDDUA) - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub
16.1 cm x 10 cm x 5.8 cm
1.2 kg
3-year warranty
P/N: IM12D1500P, SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2560 x 1600
4 x DisplayPort , 2 x microphone input mini-jack , 2 x audio output mini-jack , 2 x USB Type B , 2 x USB Type A , 2 x DisplayPort , 1 x microphone input mini-jack , 1 x audio output mini-jack , 2 x USB Type A
External power adapter
FCC, RoHS
16.1 cm
10 cm
5.8 cm
1.2 kg
Limited warranty - 3 years
0 - 80%
76QJ StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £240.14
76QJ StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.50
76QJ StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £189.49
76QJ StarTech.com DisplayPort USB KVM Switch In Stock £287.60
76QJ StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.06
76QJ StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.00
76QJ StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.48
76QJ StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.06
76QJ StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.78
76QJ StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.34
76QJ StarTech.com 2-port Dual VGA KVM Switch In Stock £67.05
76QJ StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable In Stock £342.46
76QJ StarTech.com 2 Port Dual DP KVM Switch - 4K In Stock £245.82
76QJ StarTech.com DC Power Adapter - 12V, 2A In Stock £11.71
76QJ StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
76QJ StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz In Stock £328.22
76QJ StarTech.com 4PT Dual DP KVM Switch 4K60 In Stock £568.94
76QJ StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display In Stock £469.52
76QJ StarTech.com 2 Pt DisplayPort KVM In Stock £287.20
76QJ StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz In Stock £83.26
76QJ StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable In Stock £91.46
76QJ StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £11.52
Connectivity: KVM
Ports: 2
