Control 2 high-resolution dual DisplayPort computers with a single console. The SV231DPDDUA 2-Port USB Dual DisplayPort KVM Switch with Audio and USB 2.0 Hub combines next generation digital display standards with seamless KVM control, allowing you to switch between 2 dual head or twin DisplayPort systems. Also ideal for systems with a single DisplayPort output, and a second video source such as DVI or HDMI, using a low cost accessory adapter.
Delivering multi-computer control for high-res multimedia applications, the dual view KVM supports resolutions of 2560x1600 (@60 Hz) with DisplayPort HD audio, as well as 2-channel analog stereo audio and microphone input.
Suitable for high quality static imaging, such as medical applications (MRI, X-ray, etc.), a maximum resolution of 3840x2400 is supported at reduced refresh rates.
Versatile video resolution
The KVM switch supports up to 2560 x 1600 resolution, providing clarity across dual monitors for a visual experience. -
Convenient USB hub integration
Featuring a built-in 2-port USB 2.0 hub, this KVM switch facilitates easy connection to additional peripherals such as printers and external storage devices. -
Robust operational parameters
The KVM switch functions in varied environmental conditions, with a minimum operating temperature of 0°C and a maximum of 40°C, along with a humidity range of 0 - 80%. -
User-friendly design
Engineered for one local user controlling two computers, this KVM switch simplifies multitasking and enhances work efficiency. -
Reliable compliance standards
This device complies with important standards like FCC and RoHS, ensuring it meets necessary environmental and safety regulations.
- StarTech.com Dual Monitor DisplayPort KVM Switch - 2 Port - USB 2.0 Hub - Audio and Microphone - DP KVM Switch (SV231DPDDUA) - KVM / audio switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Users Qty
- 1 local user
- Built-in 2-port USB 2.0 hub
- 16.1 cm x 10 cm x 5.8 cm
- 1.2 kg
- Black
- 3-year warranty
- Designed For
- P/N: IM12D1500P, SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 2560 x 1600
- 4 x DisplayPort , 2 x microphone input mini-jack , 2 x audio output mini-jack , 2 x USB Type B , 2 x USB Type A , 2 x DisplayPort , 1 x microphone input mini-jack , 1 x audio output mini-jack , 2 x USB Type A
- Power Device
- External power adapter
- Black
- FCC, RoHS
- 16.1 cm
- 10 cm
- 5.8 cm
- 1.2 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £246.14 |
StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio | In Stock | £192.91 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £230.07 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.28 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.56 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £2.94 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.73 |
StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable | In Stock | £351.01 |
StarTech.com 2 Port Dual DP KVM Switch - 4K | In Stock | £251.98 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.76 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz | In Stock | £336.44 |
StarTech.com 4PT Dual DP KVM Switch 4K60 | In Stock | £583.16 |
StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display | In Stock | £481.26 |
StarTech.com 2 Pt DisplayPort KVM | In Stock | £301.49 |
StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz | In Stock | £85.35 |
StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable | In Stock | £93.76 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £13.72 |
