StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black
Quicklinx: 9KRFWS00 Mfr#: DP2VGDVHD
48 in stock
£32.61 ex VAT
£39.13 inc VAT
Connect a DisplayPort-equipped PC or Mac to an HDMI, VGA, or DVI Display. The DP2VGDVHD DisplayPort to VGA, DVI or HDMI converter offers a compact 3-in-1 solution for connecting your DP-equipped desktop, laptop or Ultrabook computer to a VGA, DVI, or HDMI display.
Compatible with almost any display, television or projector, this versatile converter provides the ideal plug-and-play solution for travel or BYOD (Bring Your Own Device) applications around the office. With three of the most common interfaces to choose from, the converter equips you to walk into any boardroom ready to connect to an available display device, even if you don't know what connection ports will be available.
For seamless connections from your DisplayPort-equipped computer, the converter supports video resolutions up to 1920x1200/1080p, so you can convert a DisplayPort video source to VGA, HDMI, or DVI without sacrificing video quality.
The DisplayPort converter offers a small footprint and lightweight design that makes it easy to keep on hand without it taking up too much space in your laptop bag.
StarTech.com 3 in 1 DisplayPort Multi Video Adapter Converter - 1080p DP Laptop to HDMI VGA or DVI Monitor or Projector Display (DP2VGDVHD) - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - 20 pin DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x DVI-D output - 24+1 pin digital DVI
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - 20 pin DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x DVI-D output - 24+1 pin digital DVI - female
FCC, RoHS
Enclosure Colour
Limited warranty - 3 years
70 °C
10 - 85%
9KRF StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £6.05
9KRF StarTech.com 6 ft DVI-D Single Link Cable - M/M In Stock £6.77
9KRF StarTech.com 15 ft DVI-D Single Link Cable - M/M In Stock £13.55
9KRF StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.62
9KRF StarTech.com 18in DVI-D Single Link Cable - M/M In Stock £4.97
9KRF StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M In Stock £9.79
9KRF StarTech.com 10 ft DVI-D Single Link Cable - M/M In Stock £7.89
9KRF StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £18.34
9KRF StarTech.com DisplayPort to DVI Active Adapter In Stock £21.76
9KRF StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.14
9KRF StarTech.com 10m (33 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable In Stock £49.91
9KRF StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.02
9KRF StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £32.61
9KRF StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £17.15
9KRF StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £32.61
9KRF StarTech.com mDP to HDMI or VGA Converter In Stock £17.92
9KRF StarTech.com DP to HDMI or VGA Converter In Stock £15.28
9KRF StarTech.com mini DisplayPort to VGA DVI or HDMI Adapter In Stock £40.96
9KRF StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £22.80
Price Range Ex VAT: 0 - 50
